Question about WeighMax W-4819-55 55 LB Desktop Postal / Shipping Digital Scale 55 LB x 0.2 oz w/ Fold Up Stand & Large LCD Display, Measures in LB, oz, Kg, gm
When it turns on its says lo and shuts off - WeighMax W-4819-55 55 LB Desktop Postal / Shipping Digital Scale 55 LB x 0.2 oz w/ Fold Up Stand & Large LCD Display, Measures in LB, oz, Kg, gm
My Hayward H series gas heater will not stay ignited when I turn it to Pool the Display reads LO if I shut pool filter On and off fast it will almost start but then goes back to LO display is there a...
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Etc
Good Luck - hope this helped.
May 02, 2014 | Hayward H Series
How to Shut off Scrambler on Cp100
1) Hold in the PTT and the Monitor button at the same time. Continue to hold them in while turning on the radio.
2) Continue holding them in until the long bleeping sound stops.
3) Release the buttons.
4) Pressing the menu button will walk you through programming. Be careful not to change any settings you do not want changed. Your first press will show the frequency, next press will be code.
5) Continue pressing until you see a zero (aught) with a slash, this is the place to set scramble.
6) Using your plus or minus button change the number on the screen to be a zero (off).
7) Then press the menu button again. This will lock in your setting.
8) Continue pressing the menu button until the beep you hear is different, a little higher pitch. You are then done programming, shut off the radio and turn back on normally. Your scramble is shut off.
Note: Along the way when you see the word Hi or Lo, this is in reference to the FCC narrowband mandate in the USA. If you are in the USA this setting should be LO (narrowband).
Here is a link to the user guide (programming begins on pg 20) http://www.scribd.com/doc/51104921/CP100-User-Man
Best regards.
Dec 12, 2012 | Motorola XU2600 (6 Channels) 2-Way Radio
Why does the walkie talkie shut off when trying to taslk
If the batteries are not fully charged - or if the batteries are old an no longer capable of accepting a full charge - they may not be able to provide enough power to operate the transmitter, an shut off. If your radio supports hi / lo power settings, try switching to lo. Receiving requires much less power than transmitting, so you may not realize that the batteries need to be recharged / replaced until you transmit.
Nov 26, 2012 | Radio Communications
LO error code LG ducted
In my lg ac it automatically shut downs and restarts and lo is written in stead of temp what is the problem and what should i do?
Nov 20, 2009 | LG Heating & Cooling
My heater turns on then has a r 6 reading then shuts off?? Help!!
you must open the heater to get the code on the back of the board
Oct 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
MY bfm588dq-81 scale is malfunctioning. The
Throw it away. The product sucks. I know, I'm throwing one away right now and I"ll NEVER purchase one again.
Aug 17, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
"LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
The screen stays on when shutting off the laptop
Do you have automatic updates turned on? If so turn it off and see if problem goes away.
Jan 06, 2009 | Toshiba Satellite A100-S8111TD Notebook
WeighMax W-4819-55 55 LB Desktop Postal / Shipping Digital Scale 55 LB x 0.2 oz w/ Fold Up Stand & Large LCD Display, Measures in LB, oz, Kg, gm Logo
24 people viewed this question
Top WeighMax Office Equipment & Supplies Experts
jasbo
jasbo
Are you a WeighMax Office Equipment and Supply Expert? Answer questions, earn points and help others
