Question about Pioneer DEH-P6800MP CD Player
1 disc cd drawer keeps opening - Pioneer DEH-P6800MP CD Player
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
How do I get the CD drawer to open?
Normally, there is a small hole located below the disc drawer that you can put a straightened paper-clip in to open the drawer.
Feb 02, 2015 | Audio Players & Recorders
I CANNOT GET THE CD DRAWERS TO OPEN ON MY SHARP MINI COMPONENT SYSTEM MODEL CD-DK890N
Chances are the loading mechanism is out of alignment. Very hard to realign this mech. even the manufacturer just replaces the entire mechanism when repairing.
Dec 08, 2013 | Audio Players & Recorders
My CD writer will not open to insert the CD. What
Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
Remove the paper clip and gently pull out the drawer until the disc is accessible.
Mar 08, 2010 | BUSlink (RW4848FM) CD-RW Burner
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Pioneer DEH-P6800MP CD Player Logo
14 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
