Question about Waterpik Health & Beauty
Waterpik wp 20c removeable attachment leaks
Vintage waterpik device still works well. The removable color collared attachments are leaking. Is it possible to purchase replacements or to repair seal where plastic clear tube meets the collar.
SOURCE: Ring collar broken
wheres the soluiion??????????
Posted on Jul 23, 2008
  • 338 Answers
SOURCE: Model 587784100 My 18inch Kenmore apartment-sized
if you think you can do it then do it. it is normally not any harder than it looks. now because i work there i would say call them :) but you can change those parts fairly easily
Posted on Dec 01, 2008
SOURCE: I just purchased a Astrolon 60 mm edu-science
No -- you cannot buy parts for that telescope--- it's a toy scope. Hope you did not pay more than $2.00 for it.
Posted on Jun 22, 2009
Testimonial: "Thanks, I paid $5.00, I guess I got ripped off!"
comax
  • 154 Answers
SOURCE: Grease is leaking out. it might be a cracked
Pry the rubber tip off the bit holder with a small screw driver, then begin removing the snap rings untill all the parts are off the bit holder,(you will see how they come apart so I'm not going to explain it) With a magnet remove the (4) pins that hold the bit holder in, remove the bit holder. The shaft seal is probably leaking so you have to remove the whole gear housing. Turn the selector knob on the side of the drill to about 7-8 o'clock, push the red button in and pry it off. Remove the 4 bolts holding the housing on and remove the housing. You must remove the seal from the inside, you can't remove it from the outside. The rest is pretty straight forward. There is a retainer holding the bearing in the housing, you will have to clean the grease out to see it .Pull the bearing, push the seal out. Reverse the operation to assemble the hammer.
I know lots of stuff to do, if this is too much you may want to take it to a Bosch service center, it shouldn't take more that 30 min.
Posted on Jan 28, 2010
Testimonial: "Thanks for your help. I will try to fix it myself. I just have to find the parts."
hslincoln
  • 235 Answers
SOURCE: I have a kitchenaid 5ksm150(UK), I recently purchased an
Hello KELPIES52. I see you have two postings, with some minor differences. You say purchased an “ice-cream maker attachment” in the US and my first clarification question to you is, did you purchase the KA Ice Cream Maker, Model KICA0W, or some other brand that said it was compatible with KA mixers?
If you did buy a KA ice cream maker, then it should fit all KA models, including yours. If you purchased another brand of ice cream maker, then it may never be truly compatible, and there’s the rub.
First regardless of what brand of ice cream maker you purchased, you should have both your KA mixer’s Parts List manual and both the KA Ice Cream Mixers Parts List and Users Manuals in hand. If you're lacking them, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use 5KSM150, for you mixer and select the file 5KSM150PSEWH4.pdf (777.26 KB) listed under Parts List (1113) (you can actually choose any file sized 777.26 KB; they are all for the different color UK models) and then check to verify this matches your mixer model. This is a good file to have on hand if you ever decide to troubleshoot and fix your mixer by yourself.
After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List and the Use & Care Guide manuals (even if you don’t have a KA ice-cream maker) for your future reference.
If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer's agitator shaft. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
On the other hand, if your ice cream maker is not a KA model, you can still remove the collar, spring and groove pin if you’d like to give it a try. You will need a punch drive with a smaller diameter than the groove pin, a hammer, steady hands and plenty of patience. Tilt your mixer’s head up and rotate the planetary agitator shaft so that the flush end of the pin with the agitator shaft is facing you (the extended part of the pin is facing away from you). Align your punch drive on the end of the groove pin and give it a good whack; repeat until the pin starts to come out the other side of the agitator shaft. Continue tapping until the pin comes completely free. (Note the groves on the pin as you will need to orient the groove pin the same way when you reassemble the spring and collar on the agitator shaft when you’re finished making ice cream). Once the pin is removed the spring and collar will easily come off and then you can attempt to mount the ice cream maker drive on the agitator shaft. Caveat Emptor! Good luck, I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Feb 23, 2010
Value of resistor R1 on circuit board ? Waterpik wp-270c or wp-305c
That is determined by the order of the color bands on the resistor itself.
Dec 20, 2015 | Home
Water leak inside of unit around pump head
1. Disconnect electrical supply.
2. Remove top cover.
3. Remove pipe from elbow on top of pump body by unscrewing knurled collar.
4. Then, unscrew elbow from pump body.
5. Wrap threads of elbow with a few layers of plumbers PTFE tape.
6. Then carefully screw elbow back in to pump body (this can be a little tricky - be gentle and take your time - this worked fine on my Gaggia Classic).
7. Then re-attach pipe with collar. NOTE: The top of the pump body can be rotated by gently twisting - to get the pipe at the correct angle to the boiler and allow the pump to sit vertically on its bracket.
8. That's it! Check your machine is dry and clean, re-assemble, plug it in, prime the pump (it's in the manual) and pull a shot!
Jan 25, 2014 | Gaggia Classic Espresso Machine
When changing the oil pan on a 2006 town & country do you have tighten the bolts in a sequence?
Removal & Installation
2.4L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable Structural collar A/C compressor bracket to oil pan bolt Oil pan
  4. Clean the oil pan and all gasket mating surfaces.
To install:
  1. Install or connect the following:
    Oil pan gasket to the block after applying engine RTV at the oil pump parting line Oil pan. Torque the bolts to 105 inch lbs. (12 Nm). Structural collar Negative battery cable
  2. Fill the crankcase to the correct level.
  3. Start the engine, check for leaks and repair if necessary.
To install:
3.0L Engine
    Negative battery cable Starter motor Front motor mount bracket Bending braces Torque converter dust shield Oil pan
    Fig. Oil pan mounting bolt tightening sequence-3.0L engine
To install:
  1. Clean the oil pan all mating surfaces.
  2. Apply RTV gasket material to the oil pan.
  3. Install or connect the following:
    Oil pan. Tighten the bolts in sequence to 50 inch lbs. (6 Nm). Torque converter dust shield Bending braces Front motor mount bracket Starter motor Negative battery cable
  4. Fill the crankcase to the correct level.
  5. Start the engine, check for leaks and repair if necessary.
3.3L & 3.8L Engines
    Negative battery cable Engine oil dipstick Drive belt splash shield Strut to transaxle attaching bolt and loosen the strut to engine attaching bolts Transaxle case cover Oil pan fasteners Oil pan and gasket
To install:
  1. Clean the oil pan and all mating surfaces.
  2. Apply a 1 / 8 inch bead of gasket material at the parting line of the chain case cover and the real seal retainer.
    New gasket on the oil pan Oil pan. Torque the bolts to 105 inch lbs. (12 Nm). Transaxle case cover All bending brace bolts Drive belt splash shield Engine oil dipstick Negative battery cable
To install:
May 05, 2012 | 2006 Chrysler Town & Country
Attached hoses and they are leaking a lot LG washer WM2140CW
Turn off the water supply to the machine and remove the water supply hose(s) from both the machine and the supply taps (US=faucets).
Check that there is a rubber sealing washer in the each end of all hoses and that each washer is undamaged. If the washer is missing then chack on both the supply tap and on the machine inlet connection as it could have got stuck on those items when you disconnected. If any washers cannot be found or are damaged, then replace them. They only cost pennies from any DIY/hardware/plumbing store.
Reconnect the hose(s) and tighten by hand. If you use a wrench it can overtighten and distort or split the sealing washer. Turn on the water supply and check for leaks, if there are any then tighten any leaking connections a bit more by hand.
Other things to check are for split or damaged hoses (unlikely), split or damaged tightening collars on the hoses, or cross-threaded collars. If there is any doubt about the hoses themselves or the connector collars, then replace them. Also check that the leak isn't from the supply taps themselves. If so, then they either need to be replaced, serviced or removed and refitted to the supply pipes. If you find it is a supply tap problem and you need assistance with that issue then please report back for more guidance if you need it.
Note that there is absolutely no need nor benefit in applying PTFE plumbers tape to the hose connection threads. The washer is what does the sealing, and as the hose collars are plastic they're not going to corrode onto any metal supply taps.
Jul 08, 2011 | LG Washing Machines
Price Pfister kitchen faucet with two porcelain controllers, one goose neck spigot and sprayer, chrome. Put the unit in about nine years ago. Starting leaking from base where spigot attaches to base with...
Should have o-rings remove those and lowe's,hardware,home improvement,plumbing supply stores should have what you need.Be sure to use plumbers grease or Vaseline on new o-ring and inside spout to keep from tearing new o-rings.
Jun 01, 2011 | Plumbing
I need a service manual for my vintage WP-20W waterpik
To mp3mastr:
I don't have a service manual, but I've owned and used these WP-20W's for 30 years or so and kept them running, so I'll bet I can help you if you'd care to email me at fredhowe@frontiernet.net
Tell me what's wrong or what you might need.
Oct 06, 2010 | Water Pik Health & Beauty
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
Water leaking out of water reservoir. Not sure
I BELIVE THESE ARE JOHN GAUSE FITTINGS THERE IS A C CLIP TO PULL OUT POSS. AND THEN YOU PUSH IN ON THE COLLAR AND PULL THE LINE OUT. DONT FORCE IT
Jan 13, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Trying to figure out how to change attachment for a black and decker rtx 3 speed rotary rool
The black and decker rtx uses the Flip-Lock spindle lock system for attachment changes. At the top of the tool there is a small rubber lever just above the on-off switch. Flip the lever down, and losen the grey collar surrounding the collet. Remove the collar and change the attachment. Then tighten the grey collar, and flip the lever back up. That's all there is to it!
Jun 18, 2008 | Computers & Internet
Health & Beauty Logo
278 people viewed this question
Top Waterpik Health & Beauty Experts
Andrew Taylor
Andrew Taylor
Jay Plesset
Are you a Waterpik Health and Beauty Expert? Answer questions, earn points and help others
