Question about GE GSH22JFT Side by Side Refrigerator
Compressor wont come on - GE GSH22JFT Side by Side Refrigerator
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
COMPRESSOR WONT STAY ON
You replaced the compressor? Sea Breeze
May 30, 2013 | Refrigerators
1995 GMC A/.C compressor wont run
bypass the low pressure cut off and put in more freon
Aug 24, 2012 | 1995 GMC Sierra
17 cu fridgeidaire freezer wont freeze
More than likely the compressor is bad. A lot of times technicians will change the start device on the compressor and if it runs for a minute they are satisfied its fixed. The proper way would have been to monitor the amperage drawn by the compressor and then there would be no doubr if it was start device or compressor.
Mar 31, 2012 | Avanti Freezers
Air compressor wont start
For air compressor not working,click the link below :---http://repairhelpcenter.blogspot.com/2012/01/air-compressor-wont-start.html
-----------Thanks.
Jan 20, 2012 | Air Tools & Compressors
My friedrich unit compressor wont come on
This could be a bad capacitor or your compressor may have gone bad. Another possibility is an overload that is tripped and has to be reset manually. Hope this helps.
Apr 29, 2010 | Heating & Cooling
New copeland compressor wont start
Hello,By all means install a hard start kit on the cap.Your wiring is correct.A scroll compressor usally doesn't need a start kit but I have seen 5 ton units that take one.Check the compressor tag and make sure the compressor is not a 3 phase motor!
Apr 21, 2010 | Heating & Cooling
MY COMPRESSOR JUST KEEPS RUNNING AND WONT REACH MAXIMUM PRESSURE AND SHUT OFF. I CAN SHOOT NAILS BUT IT WONT SHUT OFF DOWN.
The compressor itself sound like it is bad. You might see what it cost to repair it. It might be cheaper to get another one...keep in mind if you do a lot of work with it that a 2 stage compressor will cool better and you won't have this type of problem again.
Oct 19, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Please help our ac compressor wont come on
Hi, did you change, capacitor for compressor too. check compressor overload switch,(relay) normally located on compressor terminals, (where you connect wires to compressor) that's the device that goes klix when compressor goes to start, could be faulty, or maybe low voltage from your mains(house panel) check line voltage, with digital volt meter, some compressor won't start if voltage drops to low, yes fan will work, could also be, your compressor has a lock rotor, (hard start), you can buy a compressor hard start kit, from appliance store, and try to start compressor, or maybe compressor internal winding, are damage, especially now in summer, when you got a lots of voltage drops, check compressor winding, check compressor winding for short circuit, remove cover on compressor, remove 3 wires from compressor terminal, use ohm meter, put one tester lead on copper tubing that's connected to compressor, and next lead to compressor terminal, one by one, if you get beep (continuity) from anyone of those compressor terminal, you got a short- circuit in compressor, you will have to replace compressor, but if there's no short, them try hard- start kit, replace overload relay, you will see it at compressor terminal location, after you remove cover. good luck.
Aug 10, 2009 | Heating & Cooling
WINDOW AIR CONDITIONER_WHIRLPOOL
Did you recharge the refrigerant gas? If it is not pressurised the the compressor wont work.
Oct 06, 2007 | Heating & Cooling
GE GSH22JFT Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
