Question about GE GSH22JFT Side by Side Refrigerator
Control panel on frezzer door wont come on.
Control panel wont come on, not even the fan in frezzer, only lights
4 Suggested Answers
robmattie
SOURCE: GE French Door Frig control panel blinking temp #s
I had a very similar problem with our GE refrigerator. The main control board looked to be the culprit. I took out the board and did a visual inspection. Upon inspection I discovered that the (2) 470 micro farad capacitors were blown. I checked the power diode near these and it was still ok. I went to Radio Shack and picked up two 470 micro farad - 35V capacitors for and grand total of $2.60 and resoldered them myself. The refrigerator has been running great since. If you want to know more details email me and I will be happy to let you know what I know. I didn't want to pay $100 for a GE guy to replace a board either!
Posted on Aug 10, 2009
heatman101
  • 43501 Answers
SOURCE: nothing operating cond fan operates slowly at
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 14, 2010
tunde007
  • 2382 Answers
SOURCE: Control panel on freezer door
Hi, your dispenser board has lost communication to the main control board. You will need to replace the board which is located behind the refrigerator, behind the 8 " X 10 " small panel. The part no# is WR55X10942. You do NOT need to replace the board on the dispenser. The board behind the refrigerator is easily replaceable .
Posted on Jan 17, 2011
Kenmore French door refrigerator will not start up, control panel will not light up, wont come on
Have you tested the outlet? The power cord itself could have a broken or burned wire. Even if boards are bad, there should be lights.
Oct 03, 2014 | Kenmore 2537031321 Stainless Steel 26.7 Cu...
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
Refridgerator will not get cold, frezzer portion works fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Jan 21, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Bottom cools and top cools but dose not freeze . Do not heart fan when frezzer is opened.
you do not hear the fan ? your evaporator fan is not working - shut off everything and remove freezer panel look for any excess ice or frust blocking the fan - if everything is clear try spinning the fan blades with your hands, is there any resistence or it spins freely ? Put back cover and turn it on - if fan fails to spin then you have to get it serviced and change the evap fan motor assembly or check the control board.
your unit won't cool if the fan is not working or working erratically.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
How do you turn off freezer,refrig. is a side by side with a lower freezer that pulls out. Recently moved and freezer door broke and need to use just the refrig.
I don't believe you can turn off the frezzer section because most if not all frezzer/fridge units use the frezzer section to cool the fridge side!!!! that's just how they are designed.
Sep 21, 2009 | Refrigerators
My fridgidaire side by side Model PHS69EJSS is not running or making any sounds at all. It has completely defrosted. All lights are on. The digital read out for the freezer is flashing E and the Fresh...
e f code is a faulty frezzer fan motor . disconnect power to reset control open frz door and push in door swt and listen for f/m to run. if f/m does not run the f/m or control board could be faulty
Dec 14, 2008 | Refrigerators
Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Sep 01, 2008 | Sub-Zero 680 / F
Cooling fan works with door open.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 15, 2008 | GE JVM3670 Microwave Oven
GE GSH22JFT Side by Side Refrigerator Logo
32 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
