Question about Rimage Everest II Printer
Error code 363
Failed to start label re-transfer on everest print. Printer sense code = 42. (Retransfer ribbon lower sensor error)
2 Suggested Answers
techwaredist
  • 30 Answers
SOURCE: My rimage is printing but
Is there anyway you can send a picture of the disc with the bad print? It may be a worn our roller which is an easy fix.
My email is - info at techwaredist dot com
We to repair work on Rimage Everest II and Everest III printers regularly.
Posted on Mar 24, 2011
How to clean the print head
No easy way to clean the print head. You will need to remove it from the printer to gain access to the area to clean. What does the label look like on the disc? Streaks is probably a dirty print head. If sections of the label are missing it could be the print head or heat roller. Look at the re-transfer (clear) ribbon. If the missing part of the label is left on the ribbon you have a heat roller issue.
Mar 12, 2013 | Rimage Everest II Printer
Have an Everest III disc printer that is not printing good labels. Seems the blue prints OK but the are streaks on the disc where the red and yellow should be printing. Changing the ribbons didn't
First thing is to completely CLEAN the printer. All rollers and any point that contacts the ribbons or transfer material.
John Norman
Max Optical llc.
www.maxoptical.com
Aug 08, 2012 | Rimage Office Equipment & Supplies
When I try printing, the label sheet comes out without being printed then stops and the "condition/error" lights blink.
First you need to check the blink rate:
If fast this denotes a ribbon error - check ribbon is installed correctly.
If slow this denotes a label sense error - check the sensors are clean and are correctly aligned.
Aug 29, 2011 | Citizen CLP-621 Label Printer
Using CD Designer I try to print my disc on my Everest II printer and it appears to be printing and then the tray opens and the disc is blank - "no image printed on the disc" I do not get any...
Check the ribbons. If your CD image is still on the color ribbon your print head is probably bad. If the image is on the transfer ribbon replace the heat roller.
Apr 17, 2011 | Rimage Everest II Printer
My rimage is printing but there is an 1in mark that appears on all my disk what can it be.....it's almost like its on a roll or something every 5in roll u get the markl..i install new ribbon and...
Mar 24, 2011 | Rimage Everest II Printer
We have a Rimage Everest II S/N 06074034 model number. Requesting Transfer paper?? Problem states "Retransfer out"
Hello Spacheco763,
The serial number provided is a DLN5200. I am assuming you are using the Everest II printer with this autoloader.
I don't think the message you are saying is the full message, but I will attempt to help.
If you just changed the ribbon and are getting an error stating there still isn't any left, go into Printers and Faxes and right click on the Everest II. In the drop down menu, choose printing preferences. Click the utility tab and open the Status Monitor. Here you can reset the ribbon count and view the status of the printer and ribbons.
If it is giving you a upper or lower retransfer ribbon error, the sensors closest to the retransfer ribbon need to be cleaned.
If this does not fix your problem, it could be a possible hardware issue. The serial number you provided is not under a service contract and will be going end of service (EOS) very soon. If you would like discuss this, feel free to give our support team a call at 1-800-553-8312 (Option 2)
Dec 06, 2010 | Health & Beauty
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Rimage Everest II Printer Logo
108 people viewed this question
Top Rimage Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
