Question about Performance Teknique Car Audio & Video
Monitor off My brand new roof monitor 1440 does not show any image, it was just installed last monday
  • Veronica Lorena Arana Muoz
    a technitian just told me that the problem is the power fontain, could this be right, he says that the screen turns on when cold, but after a while it turns off, that is because the power it has is not enough for leting it work
  • 556 Answers
SOURCE: new monitor only shows my desktop image. and nothing else
it is not monitor problem as it is showing desktop. there is problem in setting of monitor or monitor Configuration is not proper. please refer manual which you must have received at the time of purchase.
Posted on Sep 30, 2007
jcdill
  • 121 Answers
SOURCE: no image on LCD monitor
It sounds like your camera has the review time setting set to a short value like 1 second. Look in your user manual for Review Time and then follow the steps to change the review time setting on your camera. If this doesn't solve your problem, it would help to know:
1) Do you have your user manual?
2) What do you have the Review Time set for?
3) If you go to playback mode can you see the picture for a longer time?
Posted on Dec 18, 2008
preachw996
  • 1179 Answers
SOURCE: Vison Monitor ( device installer error)
First you need to uninstall the driver for your old monitor. Then install the driver for the new monitor. With both drivers installed your computer is confused and shows the conflict as an error message. Hope this helps.
Posted on Dec 23, 2008
  • 26 Answers
SOURCE: Brand New LG Computer Monitor Flickers/Goes Into Power Save Mode
well right click on your desktop and goto properties and then goto screen saver and then goto power and then on the monitor setting goto never.
Posted on Sep 21, 2009
  • 1684 Answers
SOURCE: Monitor shows on receiving signal, will not display image.
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or no picture is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
Testimonial: "Took a full year to get a response, but it was worth the wait, thanks very much for taking the time to respond."
I'm from italy and i got a problem with vw192s. It's an old model. My integrated video cart doesn't recognize this monitor and i can't set up 1440 x 900. can u halp me? thank you.
You can install as "default" or try drivers to a different model or brand, if new drivers for this model and make are not available. (See www.asus.com/support) In some cases installing the old model as a newer model can work fine, so long as the monitor can accept the mode...and windows will attempt to display at the higher resolution then switch back to the lower mode if it cannot.
Good Luck ~ Bono Fortuna!
Jan 10, 2011 | ASUS VW192S Monitor
How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Jan 27, 2010 | AOC 919Swa1 - Black 19 inch LCD Monitor
My monitor resolution is stuck on 1280 x 1024
you need to install the EXACT video card driver. what was currently installed driver might just be the compatible driver.
Jun 04, 2009 | Recoton Advent Advent Q2035A 20" TV
Image blur
You need to check that display resolution in your Display properties is set to the native resolution for wide monitor typically 1440><900 for the size you mention.
Blurred image is due to using 4 : 3 resolution setting of 1024 >< 768 on a 16 : 9 wide monitor.
Samir.
Please rate the solution and provide feedback.
Jan 02, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Dec 23, 2008 | Computers & Internet
Monitor resolution conflict
Install the Drivers for your New Monitor and then try increasing your resolution. If fails to solve, contact your Monitor Vendor (Seller).
Sahaja Yoga is FREE OF CHARGE and is the MAHAA YOGA.
Apr 23, 2008 | Acer AL1916W 19" LCD Monitor
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
New monitor only shows my desktop image. and nothing else
Sep 27, 2007 | Computers & Internet
Batteries last
The battery performance depends on the brand of battery. Alkaline batteries last approximately 120 images with the LCD monitor display on, and 140 images with the LCD monitor display off, according to our test result. Minolta's standard test method is as below: Standard image quality, full image size, using flash for 50% of exposures.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Car Audio & Video Logo
41 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
