Question about Etnies Riviera Shoes for Women
Etnies riviera black/white
Where is the battery located in 1995 buick riviera
Under the front hood in the engine compartment.
Dec 10, 2010 | 1995 Buick Riviera
Where is the horn relay for a 1992 buick riviera
Hi, the horn relay is under the hood. On the Passenger side firewall there is a black cover with that should have "Fuses" written on it. Remove it and the horn relay will be one of the black square modules. It should tell you which one on the inside of the cover you removed.
Oct 19, 2010 | 1992 Buick Riviera
Car will not crank
go under driver side of dash find after market box may have alarm name on it probably just stuffed upped under dash unhook wires tape as nec there is two heavy wires yellow or white may bee cut nec to re solder & tape car should crank & start
Aug 30, 2009 | 1995 Buick Riviera
Looking at a 3.8L supercharged Buick Riviera.
BUICK 3.8 ENGINES ARE PRETTY GOOD ENGINES.
Jul 26, 2009 | 1997 Buick Riviera
Can no find hot wire for stereo
yellow is 12v switch-orange is constant, black is ground
Jul 03, 2009 | 1996 Buick Riviera
Color code on stereo-red,yellow,&blue/white.I believe red is always hot,yellow goes to run/accessory.Don't know what to do with blue/white.It'sa flagged P.Ant.I do not have a power antenna.64 Riviera
The blue and white wire coming from the unit is meant to connect to an electric antenna and if you don't have any then you can just isolate it with some tape and leave it.It will not affect anything else.
Jun 16, 2009 | Buick Riviera Cars & Trucks
Heater/AC fan won't operate
your blower motor has gone bad and it over heats and shuts down
May 31, 2009 | 1996 Buick Riviera
Etnies Riviera Shoes for Women Logo
14 people viewed this question
Top Etnies Clothing Accessories Experts
Da Doc
Tom Chichester
Are you an Etnies Clothing Accessory Expert? Answer questions, earn points and help others
