Canon mg3120 reset - Office Equipment & Supplies
The print result in my Canon pixma mg 3120 has a distortion. How can i fix this?
If you are facing any issue with Canon printer, Contact at Canon Printer Technical Support Phone Number 1-877-778-8.9.6.9 and Get best solution by technical expert in anytime. Get more information visit us:http://printertechnicalhelp.com/canon-printer-technicalhelp.html
Nov 14, 2016 | Canon PIXMA MG3120 Wireless Inkjet Photo...
Just stoopped printing w a blinking P error code and message to contact you.
the message is not to contact fixya but the service agent for the machine
go google and type in--- workshop manual for ( make and model ) printer and if there is one available it will be in pdf version for down load
Dec 23, 2015 | Canon PIXMA MG3120 Wireless Inkjet Photo...
Cannon mg3122 prints every other line lighter then the others
Run a "nozzle check". It should show that some of the "jets" inside the print-head are clogged.
Also, try a "print-head-cleaning" cycle.
Finally, try replacing the ink-cartridges.
May 10, 2014 | Canon PIXMA MG3120 Wireless Inkjet Photo...
MP drivers could not be installed canon mg3122
You might have to open up printers and devices in conrtol panel.
Right click in the bottom toolbar (Bottom of Screen) select the toolbars option then Desktop this will add >> arrows in the bottom toolbar select the arrows you will see a list with control panel which has another list of all control panel items.
Click on >> then on the first control panel in the list select view devices and printers see if your printer is in the list or select add a device once selected windows will search for any connected devices then just follow the prompts
Mar 20, 2014 | Canon Office Equipment & Supplies
Reset canon MG3120 ink cartridges: CL 240 CL 241
you can take the cartridges out and clean the nozzles. and be careful of filling the cartridges up, you have to fill 3 cc up into each one noe more. hope it helps.
Apr 19, 2013 | Canon PIXMA MG3120 - Multifunction ...
Pixma MG3120
I think if there is a sears anyone near you should go there because they fix pretty much anything and are fairly cheap. I got my CPU fixed there once so i dont see why they wouldnt fix a printer. Hope this helped.
Sep 09, 2012 | Canon PIXMA MG3120 Inkjet Multifunction...
Canon MX330 Error 5800 or 5B00, what is it?
Error 5B00 refers to the ink absorbers being full. This is not a job for a home user and you would be best taking the machine to a repairer for new absorbers to be fitted. If you dont then ink will start to flow out of the printer onto the table!!
Jul 15, 2011 | Canon PIXMA MX330 Multifunction InkJet...
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
Jul 31, 2010 | Acer Office Equipment & Supplies
13 people viewed this question
jasbo
jasbo
