Question about Lexar Media 4Gb Jumpdrive Twistturn - Usb Flash Drive - Hi-Speed Usb - Red
How to disassemble a twist turn lexar flash drive
Format 4gb lexar jumptwist
The thumb drive you have came already formatted and ready to use. It will read as a DISK because it works the same as a CD or DVD disc. A formatted flash drive is set up at the factory and ready to be used by the new owner. Just copy what you want to move from the computer to the flash drive. When you want to remove data from the flash drive, simply DELETE doing the same as you would on your computer PC or Laptop.
Dec 19, 2013 | Lexar 8GB JumpDrive TwistTurn - USB Flash...
Lexar 16GB S73 appears as Innostor NAND Flash USB Device
can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Dec 09, 2013 | Lexar Media Jumpdrive S73 - Usb Flash...
How to install usb flash drive in windows vista?
Just plug it in and vista will automatically install the drivers for it.
Jun 30, 2012 | Lexar Twist N Turn 16GB USB Flash Drive...
HOW TO INSTALL LEXAR JUMP DRIVE TWIST TURN
Windows XP, Vista , or Windows 7 should be able to automatically detect and install it.If you have an older operating system then go here for the driver:
http://www.lexar.com/downloads
May 15, 2012 | Electronics - Others
My 2GB Lexar flash drive has stopped working. It
A flash card wears out every single time you use it. Yours has just reached its end of life - it's dead. Replace it.
May 06, 2010 | Lexar Professional High-Speed 2GB Secure...
Transfer music from computer to lexar 1gb
You just need to connect the Lexar 1Hb to the USB port on your computer and let the computer recognize it and then after that double click Mycomputer and you should see there the Lexar , just double click on it and now you can copy and paste music from your computer to the Lexar...
Jan 02, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Lexar flash drive
First, download and try to extract all the files from your drive with this tool:
http://www.lexar.com/drivers/files/ImageRescue_2.0-u(b16).zip
Second, at the moment that you are sure that you have all your files backed up, if windows recognizes the drive, try to right click on it and format
Apr 14, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Lexar Media 4Gb Jumpdrive Twistturn - Usb Flash Drive - Hi-Speed Usb - Red Logo
41 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Sunday Ojelabi
Sunday Ojelabi
Lawrence Oravetz
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
