Question about Brother Sewing Machines
"My brother compal ace won't change to a different stitch design"
It is impossible to get the stitch light to move to the next stitch design
talk2ginny
  • 34 Answers
SOURCE: Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Posted on Feb 03, 2009
  • 7 Answers
SOURCE: Design is ready, when green light is pressed nothing happens
I have had good luck contacting the Singer peoplee themselves. Sometimes it takes a couple of days for them to respond. But, if that doesn't help try this.
Can you go forward a few stitches annd then start?
If not, try condensing your design by 1-2%. This was recommended to me by Singer when I had part of a design that wouldn't stitch out. It did the same as your whole design. I tend to think it is the digitizer, not the machine in my instance. Have you tried another design by a different digitizer?
Hope this helps.
Posted on Aug 06, 2009
  • 980 Answers
SOURCE: stitch selection
Can't remember the Ace but you need to take the top off if you can and check the nylon camstack, very prone to splitting and the selecter finger getting stuck in the slot
Posted on Mar 09, 2010
steve_plevin
SOURCE: On my brother super ace 2 computer sewing machine
Had the same problem here. Took it apart and found that several tracks in the ribbon cable from the keypad to the circuit board on which the LCD display is mounted were broken hence keypad needs to be replaced. Its part number is XA4331002 and available online from Sewing World. Have just finished fitting the replacement and keypad and sewing machine are working A1 OK.
Posted on Nov 01, 2011
mizrach612
  • 102 Answers
SOURCE: I have a Hyundai 60 stitch sewing machine, the
Take the needle out and put it back in carefully. If that doesn't solve the prob, replace it with another needle, and hopefully it will return to working.
Posted on Sep 24, 2012
Hi there, I have an old Empisal Compal ACE 765 sewing machine. After servicing the machine, I cannot get the bobbin and bobbin casing to line up in the correct timing with the needle. And I do not have a...
You can find a manual for for your machine in the link. In the photo below it show the same type of bobbin as your machine. It may or may not help you. It is a little fiddly if you have never done it but take your time and have lots of patience. Having a manual for your machine is invaluable.
Joness Brother Electronic Compal Ace Model 765 Sewing Machine Instruction...
Aug 02, 2017 | Sewing Machines
Brother embroidery machine has started shifting design outline between first colour and others, about 1/2 inch can't back up to correct starting point, doesn't respond.
Did it do this on more than one pattern? Has it stitched this pattern before correctly ? You can try turning the machine off and back on and let it reset. If it is only doing it with this pattern and it's the first time you have stitched it , try again after turning the machine off and back on. If it's not doing it to other patterns and you bought the pattern contact who you bought it from as there is a flaw in the design. Have them check and resend it. I have a converter program so if you get it in a different format you can change it to your format. Sometimes it is designed on a different machine and did not convert well. When I have this problem I download it in .hus and convert it for brother. There are several free preview programs that show you the design and stitch order and let you save it to different formats. If this isn't the problem I would call brother USA +1-877-276-8437
https://maps.google.com/maps?oe=UTF-8&hl=en-us&client=safari&um=1&ie=UTF-8&fb=1&gl=us&entry=s&sa=X&ftid=0x887f76273cf4c67b:0xf6ed103a13e50c19&gmm=CgIgAQ%3D%3D this is in TN. And open 24 hr. And explain to them what it is doing.
Mar 18, 2017 | Brother Sewing Machines
The timing is out and was wondering how to fix it
Because the timing has been changed it will need to have a repairman fix it. Another possibility is to go to youtube timing sewing machines.
Feb 22, 2015 | Brother Sewing Machines
Where is reverse button on brother compal ace 765
It is located on the front of the machine on the lower right hand side.
Push down and hold the little purple bar.
Nov 13, 2013 | Kenmore 15218 Mechanical Sewing Machine
My brother pc-2800 stitch length button won't light up so I can't adjust the stitch length. Is it worth having fixed?
you might call a repair shop and tell them the problem and ask
them how much it would cost to have the machine repaired that
way you can decide.
Feb 09, 2013 | Brother Sewing Machines
Stitch selection
Mar 09, 2010 | Sewing Machines
Hope this helps.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Pr600 shunts over on big designs
You can try to calibrate the hoops by having the machine turned off and the largest hoop and smallest hoop ready hold down the start/stop button and the needle theader button and turn the machine on while holding those in, you should get a different screen that say a/d test in the upper left corner, put the largest hoop on the machine being shure the screws are tight and hit the l button on the upper right side the numbers next to the button will change, then put the smallest hoop on and hit the ss button once the thats done turn off the machine and on again and it will start normally and try your designs again if that doesnt work take it to a brother service center/ dealer and tell them to check your x-axis position
Mar 18, 2009 | Sewing Machines
Create my own designs
Your CE 250 allows you to do very basic digitizing by using Autopunch.
To activate autopunch, click on "create" from the top menu and select "autopunch" from the drop down menu. A new Autopunch wizard menu should open. Click on "next" on the browse to your jpeg file by clicking on "select". Keep on clicking on "next" until you get to the "customize stitch block" menu. Here you are able to remove unwanted blocks or change the stitching order by clicking on a block in the right hand menu and the clicking on the "Remove", "move up" or "move down" buttons.
By clicking on the radio buttons, just below the "move down" button, you can also select between Fill stitch or Satin stitch. When you are happy with your decisions, click on next and click on finish.
That is about all that you can do and autopunch will do the rest. I suggest you import a couple of dfferent clipart images and play around as discribed above to make you familiar with the program. You will also see different results by changing options.
If you are not happy with final results, I suggest you invest in a proper digitizing program, such as Creative Drawings. Visit the at www.drawstitch.com/Creative
Good Luck
Nov 19, 2008 | Singer CE-200 Quantum Futura Computerized...
Using Autopunch
Dear CJ,
You must always remember that Autopunch is a very basic digitizing program and can only digitize very basic jpeg images with clear color difinitions.
Good Luck
dupina
Nov 04, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
26 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
