Question about TruTech LMD-5702RT Portable DVD Player
When disc is in screen does not come on - we hooked it to a TV and can't figure out how to get it back to the dvd screen
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
I cannot figure out which RCA jack output do you plug the jacks into to hook up a dvd player?
AV input wire will have three connections. Red, Yellow andWhite. Out of which, Yellow one should be connected to Video Out of the DVD player, and the other two, Read and White; to be connected to the audio out left, and audio out right of the DVD player. The other ends of this wire should be connected to Video In, and Audio In socmets of the TV. Keep trace with the colour of the socket and connect it. Select the Input of the tV to AV. Switch On both the devices. If the connection is correct, you will see the logo of the DVD player on the tv screen.
Mar 19, 2012 | iLO IWT3206 TV
I have been having problems hooking up my truflat RCA TV to my Sylvania dvd/vcr player. the cable plug is hooked up to the tv and the dvd plugs are hook up. What else should I do?
Hello
If you have connected the audio video out of DVD to audio video in to the TVs front panel; what else to do?. Power up both the devices, goto the menu option of your tV, set it to vidieo mode, open the tray of the DVD by it open-close button, put a dvd disc in, push open close button of the DVD again, take the remote control of the DVD; select the chapter you want to see, sit back easy and see the recordings on the disc. That is all. OK.
Feb 12, 2011 | Sylvania 6419TC 19" TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
Parental lock
i have the same exact problem what i figured out is that i cant watch cable on it but when i hook a vcr to it i can watch movies. but when i hook my dvd player to it the block comes back on. so i hooked my playstation 2 to my vcr and hooked my vcr to the tv and i can watch dvd's that way. thats all i have sorry..
Oct 20, 2008 | JVC AV-27820 27" TV
My LED screen got damaged, and I don't know how to finalize a mini disc in order to playback on computer and transfer to DVD. Can you tell me how to finalize the DVD-RW disc so I can play it back??
My LED is damaged too...don't know how it happened, but..if you hook your handycam to your TV - you can see the LED on the TV and know where to press on the LED to finalize.
Mar 26, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Hooking up a playstation2
how do i hook up my ps2 to the TV when i hook it up i turn it on channel 03 the screen of the ps2 does not come up plz help?
Oct 14, 2007 | Video Game Consoles & Games
Scrambly TV
take a quick peek in the manual and find out where to disable the progressive scan features. may be a button on the back, or you may have to go through the on screen menu to find it. take the disc out and see if you can view what's on screen. or since you said you had a couple of movies that did work properly, put one of those in, start the movie, go into the dvd player setup menu and disable the progressive scan settings
Aug 13, 2007 | Sungale DVD-2026 DVD Player
TruTech LMD-5702RT Portable DVD Player Logo
21 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
