Question about Acer H243H Monitor
My acer monitor is stuck on a screen and I cant get back to home screen
How to remove acer gd245hq monitor cover to replace screen
How To Remove Acer Lcd Stand - YouTube
? 0:40
www.youtube.com/watch?v=i8TZSoUnk1s
Feb 10, 2011 - Uploaded by rakka1988 The "cowling" or plastic cover over the hinge where the stand enters the back of the monitor just LOOKS like it's part of the back of the monitor.
Reparar monitor ACER GD245HQ - YouTube
? 1:12
www.youtube.com/watch?v=Muz6BU7l9Ys
Jul 5, 2012 - Uploaded by C?sar ?vila
La mitad derecha del monitor no se ve?a, estaba negra, la otra mitad funcionaba bien. Cambi? todos los ...
Oct 16, 2015 | Acer Computers & Internet
I cant change the screen position on my acer v203w the icon on the menu cant be selected
Did you reset the monitor back to factory settings?
Auto adjust?
Try change the ps4 screen settings if possible
Apr 15, 2014 | ASUS LCD Monitor
Acer screen jumping
Check to see if the button is stuck on your monitor and remember the last thing you did before it started doing this problem.
Jan 15, 2013 | Acer Aspire Z5801 All-In-One Desktop PC...
Acer X163w monitor auto adjust keeps popping up
Check to see if you have any dust, or grim by the buttons. I cant recall if this monitor's buttons are touch sensitive or not, but a good cleaning to make sure they are not stuck should clear the issue right up for you!
Aug 31, 2012 | Acer X163w Computer Monitors
Computer screen stuck in hyphenation mode
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 06, 2010 | Acer AL1916W 19" LCD Monitor
My acer Model X221WSD monitor screen is pink. I've tried
Pinkish back ground can be the sign of the lamps are going bad, but usually it will also cause the screen to go into shutdown mode also. Try New VGA cable or move the VGA connectors? Does the same on other PC?
Please post back so we can guide you further toi narrow down the problem.
Apr 09, 2010 | Acer Monitor Lcd 19in Al1923 0.29mm...
Acer AL1912B, the screen is blank and the green
The problem ca be bad back light inverter circuits, bad power supply because of bad caps, bad lamps. More likely to be bad caps, see example of failed monitors because of bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 18, 2010 | Acer AL1912B 19" LCD Monitor
I have an Acer Aspire One MiniBook. I once had it hooked up to another VGA monitor. Now when I log in it shows the ACER logo and the XP screen then turns black. i can hear the windows start up sound and...
try pressing the fn key and F5 or look for 2 monitors on one of the F keys its F5 on my acer 5520 that switches display modes also try going into the bios i think its F2 as soon as you turn on the laptop press F2 or look on the screen for the key to enter setup or bios and restore everything to default save settings restart
Nov 06, 2009 | Acer Aspire One AOA150-1635 Notebook
MY MONITOR CONTROL VOLUME KEEPS COMING UP ON MY MONITOR AND I CANT MOVE IT ,WHY IS IT DOING THIS ,IT IS IN THE MIDDLE OF MY SCREEN
it is a volume button problem. first you ensure that button is stuck or not & you can checked it from computer store.
Sep 07, 2009 | Acer AL1717 17" LCD Monitor
Dead pixel
Well you have two options, endure it or take it back/destroy it/sell it. No one can fix a burnt out pixel at home. Not even sure that they do at the factory. Pretty sure they recycle the screen and replace it. If you have a burnt pixel, you're stuck with it.
Jun 30, 2009 | Acer X223WBD Monitor
Acer H243H Monitor Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
