Question about Microwave Ovens
My keypad functions on my model #KOT151-S do not operate correctly.
MY KEYBOADS DOEN'T FUNCTION,WHAT CANI DO?
Depending of course on your full model number, you may need to replace the membrane keypad or the control panel frame assembly, which comes with a new keypad.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 26, 2012 | GE Profile : JVM3670BFBB 36" Over the...
GE Microwave keypad partially working
You have a failing membrane keypad.
On some models you can order just the membrane keypad. It's more work, but it's cheaper.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, you have to order the control panel frame which comes with a new keypad already on it.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Some connectors have a lock.
You can order GE parts from Sears hereimage-4235112-10659157 and the site should have helpful exploded views.
Nov 30, 2012 | Microwave Ovens
My keypad seems to have mind of it's open...rarely offering the function that I want. I have to turn it off at the wall switch in order to get it to do anything, then I use the options available,
behind the keypad there is a control board.
google the model number and replace part.
power surges kill these boards.
turn off before replacing.
Nov 02, 2012 | Microwave Ovens
Samsung Microwave Oven Model smh918713 beeping
You may need to replace the keypad. I found there was moisture causing the problem when we boiled water on the right side of our stove which is under the keypad. I let the microwave dry out for several days and now only use the left side of stove when we boil water and have not had the problem.
Oct 19, 2012 | Samsung Microwave Ovens
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Will not operate. displays f2
F2 means you have a shorted membrane keypad.
On some models, you can get the membrane keypad replaced by a servicer or your can do it yourself, but on some models, you would have to order a new control panel frame which comes with a new keypad.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Apr 25, 2010 | KitchenAid KHMS155L Microwave Oven
Whirlpool Microwave Hood combination Model MH6150XM turned itself on without anyone touching it. The oven and the fan went on. It continued to operate when the microwave door was opened. We unplugged...
Direct spraying of cleaners on the keypad and steam from the cooktop can short the keypad.
Luckily, it dried out. Sometimes it doesn't, and the keypad has to be replaced.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Jun 22, 2009 | Microwave Ovens
Keypad Problems
Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
Many models have 3 door switches, it's wise to get all 3 replaced at once.
Mar 27, 2009 | Samsung Microwave Ovens
KEYPAD STICKING AND STOPS WORKING
Obtain a replacment keypad and replace it. The non serviceable contacts inside of the key pad or going bad.
Dec 31, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Start button on microwave does not work
Some numbers are missing off that model number. Would that be model 721.62622200?
(If not, please reply back with the correct model number off the tag)
If it's cooking with the programmed buttons, but Start is not working, it sounds like the keypad has failed.
The keypad for model number 721.62622200 is no longer available as a separate part.
So you'd have to buy the entire controller assembly, which includes the plastic frame, keypad, and circuit board, etc.
It is part # 4781W1M307A and it runs $110.10 at the Sears parts Web site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
