Question about Philips 55PP9352 55" Projection Television
Guns for PHILIPS 55PP9352
Where can I get a red gun for my Philips 55PP9352? It seems to be out because everything is green and blue and everything that is supposed to be red is almost black.
  • Philips Master
  • 8,617 Answers
Re: guns for PHILIPS 55PP9352
If you are still needing the red gun for the phillips I have a link that I will post that has one complete with yoke, Purity rings, lens and coolant chamber. Here is the link they offer free shipping also.
Posted on Feb 23, 2008
0 characters
3 Points
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
Pioneer SD-533HD5 with No Yellow
Your Yellow Gun is out of order. You should contact Service Station to get it replaced.
Aug 13, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
I have a 50 inches philips projection tv and the image that is coming is slightly dull than normal . it seems that the the sharpness is kind of reduced
please open back side of your t.v and tack soft clean cotton and clean the guns in side the tv, red/green/blue , just cleane the guns and it will come to the normal picture quality. thanks ikram baig
Mar 09, 2010 | Philips 55PW9363 55" Rear Projection...
Projection tv
the blue gun is not working properly which explains the dominance of green and yellow colors. you need to look after dry-joints on the blue gun circuit board, sometimes oil leakage from the lens may also affect the board
Mar 26, 2009 | Philips Projection Televisions
Blue gun lites but no picture from it
you should be able to go to any used appliance shop and get what you need. most of them carry on hand parts or can order whar you need
Dec 25, 2008 | Sony KP-51WS500 51" Rear Projection...
55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
Color going
your colour guns (that's what they call the light tubes that produce the 3 main colours, red/green/blue) need to be fixed. One or two of your guns need to have the liquid that protects the lens flushed out. I had the same thing and the repair man came in took the unit apart and removed one of my light guns (blue one) and showed me the dis-coloured liquid. He drained the liquid and added new clear liquid which protects the heating of the gun and everything was perfect again.
Oct 17, 2007 | Samsung PCL541R 54" Rear Projection...
Red, Blue and Green guns and optics
On a Philips 55P8241 I would remove the lower grill, (just pops off), then remove the screws at the base of the screen and lift the screen off... Be VERY careful setting it down... You are then inside the main projection. Claen the mirror, cans and lenticular screen with windex and a soft paper towel and reverse the process putting it back together.. Good Luck Bill
Jun 10, 2007 | Philips 55P8241 55" Rear Projection...
Green Picture.
i suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Jan 15, 2007 | Philips 55PP9701 55" Rear Projection...
Philips 55PP9352 55" Projection Television Logo
49 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
