Question about Westerbeke Electrical Supplies
Generator producing 130 t0 140 volts - Westerbeke Electrical Supplies
4 Suggested Answers
joboo1
  • 257 Answers
SOURCE: Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Posted on Feb 08, 2009
ROMOAS
  • 97 Answers
SOURCE: My generator runs fine but won't put out any
inside the gen head in the back their will be a 1x1x3/8" black
with 4 wire conn thing it is a rectifier theirs a hole in the center for mounting as well replace that and should be ok a big surge and age will take them out try this i willing to bet that's it unless it is smoked the part is common and avail by ebay as well as radio shack numbers will cross ref on the item good luck hope this helps
Posted on Aug 30, 2010
SOURCE: the generator produce onely 73
Check all wiring and fuses associated with you voltage regulator if they check ok, find a way to adjust your voltage regulator replace it. Make sure the unit is running at 3600 rpm as well and making 60 hz.
Posted on Jul 10, 2011
Where can i get spare parts for a hyundai hy3000si generator [ie] voltage regulator
voltage output readings are governed by rpms of the motor
check that the engine rpms are correct by adjusting the governor setting
contact hyundai generator service center for parts
Jul 23, 2016 | Electrical Supplies
My generac generator is producing low voltage
check voltage input at voltage regulator, then check output from
the regulator.
Nov 07, 2013 | Generac 5622 GP Series GP5000 6,250 Watt...
At 3600 rpms generator produces 133 volts AC
You cannot, speed is propertional to voltage on these, as they have capacitor voltage regulation. Do not use this for powering home appliances, it is common to see this design and not a problem. If you add load and it will decrease but so will the frequency
Nov 26, 2012 | Coleman Powermate Portable Generator...
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
The generator produce onely 73 volts ac on the 120 volts plug and 146 volts ac on the 220 volts plug . what could be causing this problem
Jul 10, 2011 | Coleman Powermate Premium Plus 6250W...
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Need to know the Voltage on the capacitor its 130 micro farads but i cant read the voltage details ,can any one Help ,unit has dried out and when you shake the capacitor it rattle.
if the capacitor was connected to a 240 volt circuit, you need to buy a capacitor rated for 300 volts or more. Shop for a 130 mf rated at 300 volts or more
Aug 27, 2009 | Coleman Powermate Powermate 5000W...
Voltage is high around 150 volts. I reduced the
The speed will change the 'frequency' too. You need to make sure you still have 60 Hz. You may have need a voltage regulator adjustment, not a speed adjustment.
Aug 01, 2009 | Coleman Powermate Powermate 5000W...
Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
Mar 29, 2009 | Coleman Powermate Premium Plus 6250W...
Generator output
Feb 07, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
18 people viewed this question
Top Westerbeke Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Westerbeke Electrical Supply Expert? Answer questions, earn points and help others
