Question about SuperMicro SC825 TQ-R700UV - Rack-mountable - 2U - extended ATX - SATA/SAS - hot-swap - power supply... (CSE-825TQ-R700UV) eATX Rack-Mountable Case
Front panel pinout
I am looking for the front panel pinout for the power switch and LEDs.
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
Jan 03, 2013 | IBM Computers & Internet
I need to know front panel pinout values for IBM NetVista 49P15
THE VENDOR HAS THE PIN LAYOUT AND SOME OF THE PLACE WHERE YOU DO BUSINESS WILL HELP WITH GETTING YOU THE DIAGRAM PAPER WORK.
ROD
Feb 16, 2009 | IBM (33P0825) Motherboard
I need the pinout for the Panel 2 connector Shuttle MV43V v7.3
Hi mrdcoe,
Here's the pinout you needed.
If you need more information about your motherboard, you can always download the manual from this link,
http://eu.shuttle.com/download/Archive/Manuals/en/mv43p_n/mv43pen.zip
Good luck,
Don't forget to rate my solution, thanks!!!
Jan 15, 2009 | Shuttle MV43VN Motherboard
P4VMM2 motherboard
You can download the manual from here (Europe) or here (US).
Sep 17, 2008 | EliteGroup P4VMM2 Motherboard
PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Jul 25, 2008 | Mercury P4VM800M7 Motherboard
Front panel Pinout
the pins are usually labeld on the board itself or in the board manual
May 22, 2008 | IBM NetVista PC Desktop
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
SuperMicro SC825 TQ-R700UV - Rack-mountable - 2U - extended ATX - SATA/SAS - hot-swap - power supply... (CSE-825TQ-R700UV) eATX Rack-Mountable Case Logo
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
