Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Lines on documents - Konica Minolta bizhub C250 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
When using the document feeder??? if so then place a document on the big glass and make a copy if the line goes away clean the small slit glass to the left of the big glass that glass is what the doc feeder uses
Posted on Jan 19, 2016
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
Got a dark line down document when scanner via AFD
When you use the adf, the scanner remains stationary at the far left side of the platen. Check and make sure that the glass is very clean there; use a damp cloth to remove any dirt or other foreign material.
May 27, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Line down the scanned document on a HP LAser Jet 3050
If you are scanning using the Auto Document Feeder be sure to clean the glass where the documents get scanned. A small speck will cause a line down the page. On HP there is often a narrow strip of glass on the left side of the platen glass.
Apr 10, 2009 | Brother IntelliFAX 4100 Laser Fax
Line through scanned document when using the document feeder only
try cleaning the glass scan bar on the unit with a clean soft cloth.
Feb 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
