Question about AO Smith Pool & Spa
What the white handle valve for - AO Smith Pool & Spa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AO Smith Master
  • 1,448 Answers
Need more info where is this handle located
Posted on Mar 21, 2014
The flush valve gets stuck after each flush
Often it's the rod just inside the tank that is hitting the white nylon nut that tightens the handle. Hold handle and bend rod up a little. Over time people sometimes push too hard on flush handle it tweaks that rod.
Jan 30, 2015 | Home
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
The valve that you turn to change fil prositions the white ring under handle bnoke
Find the position where the pin that runs through the handle lines up with the slots in the valve top. Drive the pin through the handle with a punch and remove the handle then just drop a new ring in placeand replace the handle.
Aug 15, 2011 | Hayward SAND FILTER, PRO SERIES
When delta shower faucet turned on the water comes out of tub spout as well as the shower head, rough in valve is installed correctly with the word up, up
Sounds like the delta people forgot to install the diverter piece inside of valve body,small white plastic piece screwed into valve. If you take out valve you should see it up inside body
Jan 28, 2011 | Delta & Single Handle Shower Faucet
My taps are new. When the handle is turned full hot , the water is only tepid. I think the anti scald feature is letting too much cold water pass. Please advise
there is a splined adjustment just under the handle of the 3175.
you need to remove the handle, usually held on with an allen screw
once you remove the handle, there will be a black "stop" held on with a screw, remove that, but remember its position.
once that is off you can adjust the temperature. there will be 2 white pieces, one has splines, you can move this counter clockwise one or two notches at a time untill you reach your desired termp.
be careful not to go too much, even though these are an anti scald valve, you are letting more hot water through it.
Aug 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The water leaks from the top of the valve when the handle is fully opened.
You may have to put a new repair kit in faucet, but you might try tightening the adjusting nut under the handle. Loosen set screw in handle, and remove handle. There is a nut there with 4 notches in it. Delta gives you a combo allen wrench/spanner wrench for this. Try to tighten this nut. If you can't you can buy a new repair kit for this valve for about 10.00 that comes with wrench
Jun 27, 2010 | Delta Model 470: Signature Kitchen...
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
Jun 03, 2010 | Moen & One Handle Tub & Shower Faucet
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
Temp control doesn't allow water to get hot enough
remove the handle and there should be a white plastic deal behind the handle that you can remove it's a temperature limit setter so people dont burn themselves remove it and you will get the full hot water
Aug 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Carpet steamer continually sprays water/cleaner. Can't stop it!
This is a solution for the Bissell Pro Heat, although it may apply to other Bissell steam cleaners as well. This is for the problem of the cleaning solution continually spraying without stop.
I found a quick and simple solution to this problem.
This problem occurs because the valve that allows the solution to flow gets "sticky" and will not close. The valve is engaged by the trigger mechanism in the handle. Squeezing the trigger pushes downward on the valve's plunger, but the spring in the valve that is meant to push the plunger back up to the closed position is not capable of doing so.
Here's the solution:
This valve is white and resides about half way down the vertical handle portion of the cleaner. To get to it, unscrew the 2 black screws that hold the top part of the handle to the bottom part. These are the same screws that you used for assembling the cleaner when you first bought it. Pull the top portion of the handle up and it should slide out.
Now, looking down into the handle body of the remaining portion of the handle, you'll see the top of the white valve. If you push down on the top of the valve (like the trigger mechanism in the top part of the handle you just removed does) it may go down some, but it probably won't go back up by itself like it should.
I found that lubricating this plunger with dish soap was the trick. If you can't get enough access to the valve to do this, you can remove the seven phillips head screws in the lower portion of the handle and pry it apart. I did this. I even took the valve out and put soap around the plunger and into the valve itself. I worked it up and down until it had a quick and positive open/close action.
Reassemble and you should be good to go. You'll notice that the trigger now has a more positive feel to it. I hope this helps.
Dec 14, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Pool & Spa Logo
19 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
