Question about Canon imageRUNNER 210S Copier
Where is the paper pickup unit located in Canon Image Runner?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Pls write down the model and details
Posted on Feb 17, 2014
SOURCE: Canon image runner 3100 - How do I remove the drum
I have error 000020-01a2 plese hel me
Thank you,Nick
Posted on Nov 07, 2008
color_50
  • 22 Answers
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Posted on Mar 14, 2009
  • 153 Answers
SOURCE: canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Posted on Apr 09, 2009
  • 153 Answers
SOURCE: waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
Posted on Jun 01, 2009
iservice
  • 318 Answers
SOURCE: I have a Canon Image runner 1023. when I print i
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Posted on Dec 09, 2009
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Problem with image runner 400 Error : 051
Believe or not..... I had this problem once and it drove me nut's... The solution was that the dupexer jogger arm was not finding HP. It is located right above the paper feed unit, it sit's on top of the unit. From what I remember I had to replace the flat drive gear. Good Luck
Aug 30, 2010 | Canon imageRUNNER 400S Copier
Canon image runner 2200 has paper jam. I'm missing the manual to check the paper path
On display should be detaild description where the paper is jamed. In duplex, in fixing, in cass.,...
If there is no paper picked up - change rollers from cass., if the paper is got out or pass fixing unit, check the sensor flapper in fixing unit - if respond is slow apply wd40 on it or replace it.
May 18, 2010 | Canon imageRUNNER 2200
Our Canon Image Runner is showing the error message.....E00001-0010 What does that mean? Thanks
You have a problem with our fuser assembly - located where you pull out the left printer door - it is the very hot assembly where the paper leaves the machine - it will either have a yellow or black felt cover. Only two screws hold this unit in - one at the back and one in the font. Take this unit out and look for trapped paper in the rollers that could also cause the fuser temperature readings to be incorrect. If you cannot find any paper, reset the code in service mode and turn the machine off/on. If the problem returns as you power on - you will need a new fuser unit. To clear the fuser error enter service mode as follows:
Press the head key (head shape with star inside) - 2 and 8 at the exact same time - then HEAD key again. You should now be in service mode. Now - COPIER - FUNCTON - CLEAR - ERR - OK. Then turn off the power and on again - this may cure your problem indefinetly or definetly. But even if you find paper in the fuser, you mUST perform the CLEAR procedure or the error code will not go away. Good luck.
Jan 27, 2010 | Canon imageRUNNER 5000 Copier
The canon runner s5000
1)u must verify which location of the first paper jam occur.
2)pick up unit > feeding >fuser unit> output delivery unit.
3)try to use platen glass for copying instead of using the auto document feeder unit.then u can narrow down the issue.
Sep 11, 2009 | Canon imageRUNNER 5000 Copier
Remove a paper jam under the fuser unit on a canon image runner 5070
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Aug 17, 2009 | Canon imageRUNNER 5000 Copier
How to remove 4 cassette unit from canon machine IR 400
THIS WILL BE SOFTWARE SETTING ON THE CONTROL PANAL
CANON IMAGE RUNNER 400S COPIER USERS GUIDE
OR
CANON RUNNER 400S SERVICE MANAUL DRIVERS
OR
WWW.CANONUSA.COM/COPIERS
ROD
Feb 09, 2009 | Canon imageRUNNER 400S Copier
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
E051 sensor location
It is located behind the paper pickup unit on the pre-registration guide. There is a teeny tiny motor with a tiny plastic gear and the gear cracks which stalls the motor. The purpose of the sensor and motor are to find the front (or is it rear?) edge of the paper coming out of the duplex unit so it can accuratly line up the images on the paper.
Apr 03, 2008 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 210S Copier Logo
old marine
old marine
