Question about 2001-2006 Chevy Tahoe 2WD Front Wheel Bearing & Hub Assembly
I have a 2006 Chevy Tahoe 2wd. When I drive in it makes a grinding noise from the front axle. I replaced the brakes and both hubs and the noise is still there. I checked the brakes for uneven brake wear to see if the caliper was sticking and they look to have normal wear on them. Any ideas of what else it could be?
Could be a wheel bearing. jack up the front end and secure with a jack stand or two. grab the tire at 12 o clock and 6 o clock and see if you get movement. also since it is 2 wheel drive the tire should be easy to spin. While it is jacked up spin it as fast as you can and see if you hear the noise. Some shops have a little motor with a wheel that they do this with. Hope these help.
Posted on Feb 11, 2014
Why do I hear grinding noises while driving?
Hit in the rear axle may have damaged bearings or brake parts. Jack up the side you hear noise from, put on stand, then have helper rotate wheel while you look underneath and listen to see where noise is coming from. Use length of old fuel or heater hose, one end in ear, to locate exactly where noise comes from.
May 27, 2015 | 1996 Jeep Cherokee Country
05 chevy equinox makes grinding noise when I turn left.
Cv shaft is bad, ( drive shaft from Trans to wheel. )
Jan 28, 2014 | Cars & Trucks
My 2002 ford expadition is still making the grinding whoop whoop noise, I took it to a machanic and they said it was the roter or brakes or ball joints, so I got all replaced on both sides and it is still...
If the noise only happens when you are moving, and it changes with the speed of the truck, its something that is connected to the wheels.
Road speed does not affect suspension noises like ball joints and spindles.
So it would be something like the brakes, axle joints or bearings, or something in the differential where the axles come together.
If the truck is 4wd you have front hub bearings behind the brake rotors, and regular bearings if it is 2wd.
Apr 08, 2013 | 2002 Ford Expedition
Grinding noise at 40-55mph
Check front Wheel Hub Bearing Assy's
Noise should be noticable from 25 thru 45
Could also be bad drive axle cv jonts
Dec 01, 2012 | 2006 Nissan Altima 2.5
2006 chevy cobalt transaxle noise , i blocked car up remove both front wheels started engine, engaged transmission to drive, listened to noise sounded a bit like a grumbling/grinding noise., no fluid leaks...
WORN FRONT BRAKE PADS WILL MAKE GRINDING NOISE IF PAD WORN DOWN TO RIVETS RUBBING AGAINST BRAKE ROTOR WILL MAKE GRINDING NOISE, IF BRAKE PADS OKAY WORN DAMAGE DRIVE SPROCKET SUPPORT BEARING .
Oct 25, 2011 | 2006 Chevrolet Cobalt
I have a 2005 ford explorer suv, is making a big noise in the front end. I can not move the car anywhere. It all started when I tried to use the 4 x 4 the other day. I have changed both axles (left and...
sound like the hubs may be bad and not completly disengaging or engaging, this will give you a loud clucking grinding type noise,i would remove the hubs and see if they are working good, or put selector into 2wd and jack the front of the truck off the ground and spin the wheel to see if the axle moves, this is so common, a think this year has the vaccum control hub too, the hubs are common, you will need to make sure the vaccum lines are connected and clear of dirt, this sound you speak of i know it sounds like it grinding metal, theres also a module that goes bad but you will need to start with the hubs.
Jan 12, 2011 | 2005 Ford Explorer
98 Nissan Altima Grinding Noise? My mother in law has a 98 nissan altima with an automatic. She recently had the rotors turned and a tie rod end replaced at a local shop. A couple days after the work was...
Hello i would check your wheel bearings or sometimes called bearing hub .Jack car up prop the car with axle stands now remove your tires and rotors once removed wiggle you bearing hub left to the right your bearing hub should have minimal play one side to the other is obvious the looser play hub will be your noise you have been experiencing.most people call this road noise.
Jan 01, 2011 | 1998 Nissan Altima
I have a 2006 Chevy silverado, when it's in 4 wheel drive I get a squealing noise from the front end when I get it up to about 40 MPH.
you need a might new hub internal bearing wiped out the seal goes and grease escapes and then bearing goes check for oil around both left and right hubs or check axle oil level and oil around housing
Feb 09, 2010 | 2006 Chevrolet Silverado 1500 2WD
Banging noise in 4 wheel drive under torque. front hub questions.
Hello scotch1812, those of us that still enjoy the square headlights have to stick together! The front axle in our YJ's are dana 30 with a high pinion! The high pinion make the ring and pinion spin in a reverse rotation from the dana 30 found in CJ and TJ Jeeps. When Chrysler designed the YJ front axle, they removed the manual hubs like those found in CJ models and installed a vacuum disconnect on the passenger side axle shaft. The passenger side axle shaft is 2 piece with a sleeve that is moved into place to connect the 2 pieces of axle shaft when you shift the transfer case into 4 wheel drive. This is done via a vacuum module mounted on the axle housing. If your module diaphram goes bad you have no 4WD! If your vacuum hose comes off of the module or breaks you have no 4WD. Now when your transfer case is in 2WD the front driveshaft does not turn. The vacuum disconnect allows this to happen. As for the hubs, they are simply hubs with sealed bearings and a universal joint to allow your front wheels to turn left and right. If you hear the banging noise in 2WD it could be a bad universal joint in one of your axle shafts.
Now if you are hearing the banging noise only when you are in 4WD there could be a number of reasons. You could have a broken axle shaft or a bad bearing in your ring and pinion. Your front driveshaft could be bent or at least not straight. I would start with the driveshaft. Just lay under the Jeep (Not running! With emergency brake set!) and spin the front driveshaft. If it spins true and doesn't have an out of round rotation we can rule that out! Also, grab it and push it and pull it to check to see if your universal joints in the drive shaft are gor and tight! They can make a grinding noise or popping noise if they are bad!
Try these and let me know what you find! We will find your problem!
map6260
Mar 13, 2009 | 1992 Jeep Wrangler
2001-2006 Chevy Tahoe 2WD Front Wheel Bearing & Hub Assembly Logo
95 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
