Question about Lexmark Wheelwriter 1000 Typewriter
Lights come on blink and it will not move - Lexmark Wheelwriter 1000 Typewriter
Isuzu bighorn transmission light keeps blinking
When this light blinks it indicates a problem exists with the electronically controlled transmission, have it scanned for the fault code that is store in the control module.
Feb 20, 2012 | Isuzu Ascender Cars & Trucks
I have an IBm Wheelwriter 5 typrwriter. When I turn it on the line space lights blink and I cannot type or get the casette to move at all.
How many beeps? Which Lights? Blinking together or sequentially? These will help to determine the problem.
DickyO
Aug 04, 2011 | IBM Wheelwriter 6 Typewriter
Two lights flashing on printer
Hi
First of all This is a very lovely printer and my Favirout.
Can you please tell me which lights blink and their pattren of blinking?
If both the lights are flashing in the same timing then there is a cartridge stall. If this is the problem then try to move the carriage and if it moves then all you need to do is clean the steel rod and put little oil on it and move the carriage from left to right so the oil can be spread evenly.
DO RATE MY SOLUTION
Thanks
Jun 29, 2011 | HP DeskJet 920c InkJet Printer
Lights blinking
If chair is in freewheel it won't move until you move the levers to the drive position usually in rear behind the motors
Jul 04, 2010 | Pride Mobility Products Used Jazzy...
Merits wheelchair has a dynamics d l 4.2j controller
Hi. You say that the lights blink? Do all the lights blink, or just some. If its just a few then it is probably a fault code. Count how many lights are flashing and let us know and I will be able to look it up. Do you have either of the motors in free-wheel. The brake units have small micro-switchs on them, and the controller will not operate in either switch is on. Also check all battery and motor connectors. Good luck. Neil.
May 26, 2010 | Electric Health & Beauty
The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
May 12, 2010 | Jet 3 Ultra Power Chair
All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
Jun 06, 2009 | Jet 3 Ultra Power Chair
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Lexmark Wheelwriter 1000 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
