Question about Linksys NSS6000
Default Ip address for a linksys nss6000 - Linksys NSS6000
  • 196 Answers
SOURCE: Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Posted on Feb 16, 2006
  • 84 Answers
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Posted on Feb 11, 2008
jonniewalker
  • 1029 Answers
SOURCE: well you please tell me
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
  1. Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
  2. Be sure also that your printer can print when it is connected directly to your computer.
  3. Click on Start go to Printers and Faxes.
  4. Right click your printer and go to Properties.
  5. Click on the Ports Tab on the top.
  6. Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
  7. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  8. Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
  9. Select Custom, click Settings.
  10. Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
Posted on Jan 22, 2009
  • 106 Answers
SOURCE: how to reset settings of linksys srw2008p 8 port switch.
hmm.. router? try to check the router if it has an reset switch then press it with in 5-10 seconds...
Posted on Feb 04, 2009
  • 96 Answers
SOURCE: Hi there,
There are a variety of ways to display the NSS Login window.
•Open the Web browser on your computer: In the Address field, enter "http://NAS<MAC address>" (For example, "http://NAS0018F804E44C".)
•Browse for the NSS from the My Network Places window.
•Select the NSS to a network drive from a mapped network drive.
The NSS Login window appears:
Also please follow the below link for manual it will help you to setup
http://www.cisco.com/en/US/docs/storage/nass/csbcdp/nss/nss4000_nss6000/getting_started/guide/linksys_gs_feb0708.pdf
let me know if this worked for you
Posted on Dec 01, 2009
Testimonial: "good"
Wanted to set password om my linksys
Reset your router back to it's factory settings by holding the reset button for about 5 seconds.
I have provided a list of the most popular router brands. If it does not work you may need to
google what your specific model's default IP address/default username/default passwords are, for
example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it
can depend on where you obtained your router. If you purchased it yourself from a store then the
standard defaults should work. If you obtained your router from your Internet Provider you may
need to contact your service provider. It also may depend whether it's an old or new model router
as well. And you may need to press and hold the reset button on your router several times before
it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or
192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
There is no default ip address for Linksys wap610n
The configuration URL (IP address) for the Linksys is -
http://192.`68.1.1
The default login = admin
The default PW = admin
Feb 13, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Step 2:
NOTE
Step 3:
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How to get the ip adress from a linksys rtp300 phone adapter
I'm not sure if your asking for the IP ADDRESS of your Linksys or the DEFAULT GATEWAY of that device because your router's ip address will be provided by your server or Internet Service Provider (ISP) depending on your service. There are two ways of obtaining an ip address first will be DYNAMIC, where your ip address changes all the time and STATIC where you are given specific ip addresses for example 192.168.0.1 -to 192.168.0.25. The easiest way to obtain those ip addresses, by the way, is to contact your Internet Service Provider (ISP)
example: AT&T, Roadrunner, Time Warner, etc....
But, if your looking for the DEFAULT GATEWAY for you to access your router's configuration, most of the time it is found underneath the router itself. For Linksys the Default Gateway is 192.168.1.1
>I hope i helped you out with this... Enjoy!
Sep 15, 2010 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
My ip address should be 192.168.1.1 in the setup tab inlynksis but isn;t how do i change it manually
The default IP address of the Linksys router is 192.168.1.1.
First check the IP address of your computer.
START ==> RUN ==> type cme and hit OK==> you will find the command prompt. Type " ipconfig " in the command prompt and hit ENTER.
Now you will find the IP address and the Default.
Default Gateway is the IP address of your router. with this number you can open the set up interface of the router. and change the IP address of your router.
For more info about networking Click Here
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
IP ADDRESS
I need to know a little bit of information. Could you please go to start>run>cmd. In the command prompt type "ipconfig /all" without the quotation marks. Please let me know the information displayed.
May 09, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Factory settings for a Linksys RV042
Feb 11, 2008 | Linksys : RV042 4-Port 10/100 VPN Router...
Linksys NSS6000 Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
