Question about Porter Cable Cable BN125A Factory - Reconditioned 18 Ga., 1 1/4" Brad Nailer Kit
Porter Cable BN125A air escaping full pressure thru the top exhaust
After firing the first brad, air escapes full pressure thru the top exhaust
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
Needs oiled regularly
Posted on May 05, 2014
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: air is escaping from the top of the bn125a brad
it sounds like you have a damaged o ring/seal that requires maintenance. You can go to Dewaltservicenet.com and download a breakdown for this tool and also order parts for it. When reinstalling new o rings don't forget to put a little bit of grease on them so they don't roll or pinch. Let me know if you need more help
Posted on Nov 15, 2009
When i connect the air it sounds like all the air is escaping.
depends on where air is escaping from. If it is around the trigger then you need a new trigger valve (I have detailed instructions in the tip section on repair) If it is leaking thru the cap you have a pinch o ring or stuck firing valve. Let me know exactly where air is leaking and I will try to pinpoint the problem for you.
Mar 19, 2012 | Stanley Ring Kit for Bostitch N64C 1...
The gun constantly exhausts air when connected to air compressor. Won't build up the pressure when connected. Must disconnect between firing trigger
Easy fix if air is leaking out the top of gun. Remove the head and lube with white grease or silicone paste. If orings seem to be loose, order repair kit from dewalt (you can tighten orings by removing the oring and wind a bit of teflon tape in the oring groove). If air is leaking from the trigger, replace the valve. If air is leaking out the bottom where the nail ejects, pull out the cylinger and lube the orings that seal the cylinder to the body of the gun.
Oct 19, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
I have a Craftsman brad nailer. Today it started discharging the exhaust air slowly after each fire. It's like it "hisses" for 4 or 5 seconds before it's ready to fire again. It used...
Over time grit /debris enters the gun thru the hose. Remove the head and clean orings and the surface that they contact. Remove fine scratches with 400 paper. Apply silicone paste lube to orings and surfaces (silicone paste is sold at Lowes in plumbing department and swimming pool supplies area). Should be ready to work. Good luck with your repair.
May 12, 2011 | Sears Air Tools & Compressors
SLP 20 Leaks air from top and I Just replaced the chamber and o Rings.
The slp20 uses a firing valve part # ba0119 black plastic w/rubber boots. This valve is what prevents air from leaking thru top of gun. If pin hole has developed, or oring # lb0012 is not in place under the firing valve or if the retainer # bf0149 does not fit snugly on cylinder or has cracks, the gun will leak. Assuming oring is in place and retainer is good, suspect firing valve. Good luck
Mar 26, 2011 | Senco Fastening Systems No.43OOO1N SLP20...
I have three nailers from CH and all of them sound like there is not enough pressure to fire the nail when i depress the trigger. i hear air escape, but it is at a reduced level compared to normal...
Check and adjust the air pressure at the compressor. All air tools have a recommended range of pressure, and you may not have enough air for the tool to work. Also, place two drops of pneumatic oil or light machine oil into the air inlet at the nailer, and then connect the hose. Fire the gun several times into scrap wood. Oil with 2 drops daily.
Best regards, --W/D--
Mar 06, 2011 | Campbell Hausfeld Air Brad...
Bn125a nailer not sinking nails all the way
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
Nov 26, 2010 | Porter Cable Cable BN125A Factory -...
How do I adjust the depth of the brad nail on the porter cable BN 125A brad nailer
Hello. To adjust the depth of the nail you have to increase or decrease the air pressure from the compressor. Look at the compressor and you will see a knob or dial that you can turn to increase or decrease the air pressure. Do this adjustment in small increments testing the nailer by driving nails into a scrap of the same material you will be driving the nails into on the actual job. Increasing the pressure will drive the nail deeper and decreasing the pressure will drive the nail less deep. Joe
Nov 10, 2010 | Porter Cable Cable BN125A Factory -...
Porter Cable Cable BN125A Factory - Reconditioned 18 Ga., 1 1/4" Brad Nailer Kit Logo
748 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
