Question about Jenn-Air Freezer Jenn Air Clear Cube Ice Maker
WHERE IS THE WATER FILTER LOCATED ON MODEL # JSD2789DES
    New Friend:
  • 41 Answers
Hi
Check behind the cover at the back of your fridge.
Posted on Feb 23, 2014
WATER FILTER WILL NOT ENGAGE
Hi friend, I appreciate your post!
I see your question is labeled under Frigidaire refrigerator, FGHB2844LF, and you are having difficulty engaging the water filter. Based off that model you should be able to push on the face of the water filter and slide the old cartridge out. First, to install the new cartridge you would need to remove the caps off of it. Secondly, using the alignment guide slide the new filter into the housing until it stops against the snap-in connector. Thirdly, push firmly until you hear the click which indicates that your filter has been engaged. Lastly press a glass against the water dispenser to verify no leaks are present at the filter housing. Hope this helps. -Matt
Aug 02, 2014 | Frigidaire Gallery FGHB2844LF 27.8 cu. ft....
Why is icemaker not working
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, model# FPHG2399PF. Please follow these steps to resolution:
    1)Make sure the ice maker power switch is on. This button is located on the ice maker itself.
    2)Make sure there is not a small cube caught in the ice maker itself. If there is, carefully remove it.
    3)Check your water filter. Water filters should be changed roughly every 6-8 months. Also make sure your water filter is seated correctly. Try taking out the filter and re-installing it. Listen for 2 clicks and make sure it is flush with the water filter housing.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FPHG2399PF Professional 23 Cu....
Ice maker don't work
They are usually located behind the compressor compartment panel. remove the panel and follow the water line you should see the water valve. If there is a water filter in your unit these can plug up ,and cause no water to enter the icemaker. I alo have had bad icemakers.
Mar 25, 2014 | Maytag MFI2269VEW 22.0 Cu. Ft. French-Door...
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
Ge profile refrig - watrer dispenser does not deliver water. Ice maker works fine. What is wrong?
Water solenoid at the rear of the fridge has failed, there is two or three solenoids there, locate the one that does water feed to the door (not ice maker) and do a load test or just replace. Also make sure you dont have a filter safety cut-off, check filter cond and it is located perfectly in housing, check lines inside and outside fridge unit for obstructions. Good luck.
Feb 27, 2011 | Continental Freezer Wide...
Cannot find the water filter to replace it
model #? some are inside the unit, some are down below in the grill area (below doors) hope this helps
Sep 29, 2009 | Maytag Freezers
Water inlet valve - where is it located - model RCA MSX27D
The water inlet valve is located near the bottom in the "back" usually on the side the icemaker is located. On certain style freezers (boats, etc.) the inlet valve may be located at the bottom in "front" on the icemaker side.
Aug 11, 2009 | Freezers
Orange light in the shape of a leaking bucket. Side by side fridge/freezer with ice maker and water dispenser
I think you are referring to the water filter alarm. When it first starts coming in, you only notice it when you blink. As time passes, the color becomes more pronounced....If this is right, we'll move on from here, if not, please re-post, and please don't mention the village idiot (me).
The alarm can come on if a high differential pressure is sensed across the filter, or it can come on at pre-programmed times. If the fridge is relatively new, and the quality of the water is good, you can reset the alarm. On my model, I hold down the "ice type" and "child lock" buttons for about 5 seconds. The actual filter is located in the fridge, on the upper right hand side. These filters are somewhat expensive. I say that to say this....You can extend the life of your filter by installing an in-line filter between the wall water valve and the back of the fridge. This will act as a pre-filter for the Samsung filter. They cost usually about a quarter of the cost of the Samsung filters, and are easily replaced. Should you decide to replace your filter, Ebay is a very good source at a less than retail price.
Hope this was what you needed...regards --W/D-- Please feel free to rate this solution!
Jul 28, 2009 | Freezers
Poor tasting Ice
There could be a filter installed. The filter usually looks like a long tube about 6-10" long and about 1-3" round.
Try to located the water line. This will be either a copper or plastic tube about 1/4" diameter and will be going into your fridge from the back of the unit.
The filter could also be located at the point of where the water is being supplied from. Possibly under your sink or it could of been tapped into another line in the basement if you have one.
If you located a filter, you will be able to see if you would be able to remove it and replace it on your own. It usually takes a couple of wrenches, but MAKE SURE YOU SHUT THE WATER SUPPLY OFF FIRST before attempting to remove it or else you might have to go swimming. (Actually it's a small tube, so not a lot of water will come out, but you still need to shut off the water supply to the fridge. Then you can bring the old filter into your local hardware store and get a replacement.
I hope this helps.
Good luck.
Mac =)
Mar 20, 2008 | Freezers
Freezers Logo
79 people viewed this question
Top Jenn-Air Freezers Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Bailey's...
Bailey's...
Are you a Jenn-Air Freezer Expert? Answer questions, earn points and help others
