Can the ring sound on my kxtg4222 be changed ??
Two extra cordless handsets
SOURCE: 5.8 ghz mulit-handset cordless phone
How do you get the ringer on this phone to work?
Posted on Dec 14, 2007
SOURCE: GE 21008GE2-A Dual-Handset cordless phone
Here's what seemed to work for me.
Hit the button that says ringer. then hit the number 1
then hit the button marked program (it is also the
mute button). Some combination of those moves
helped me go from Ringer OFF to Ringer ON.
Rocky on the River
Posted on Jan 13, 2008
bbtoast
  • 319 Answers
SOURCE: Extra handsets no longer seem to work. No ring and no line
Please be sure to put the extra handsets in the MAIN base station to register. They will not register in the small remote charger stations.
Let me know if that fixes the problem!
Brian
Posted on Jun 17, 2008
SOURCE: BT Calypso 225 cordless phone
Check the userguide at www.bt.com/help/userguides
Posted on Jan 18, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
Hanged batteries in handset but phone will not ring
Check to see if ringer is set to hi. make sure ringer is turned on. Check to see if the base and the phone are syncronized.
Jan 03, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
Tip
Connecting extra handsets to main base
Call your phone, while it is ringing put your extra handsets on the main base. I did this and they started to ring when on the base and they worked after that. You may not need to call the main line, only put the extra handsets on the main base to get them connected but I didn't try this so I don't know.
on Oct 18, 2008 | Uniden Cordless Phone
How do I remove the silent mode from my uniden cordless phone handset
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Feb 18, 2013 | Uniden DECT 6.0 Cordless Phone with...
Panosonic phones will not ring. I can call out but ringer does not work when someone calls me
mY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Dec 06, 2012 | Panasonic KXTGA410M 19 GHz Cordless...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
Brian
Jun 15, 2008 | GE 25942GE2 Cordless Phone System
How do I change ringing to all handsets at the same time
SET ring to standard and not musical or distinctive ring. SINCE I am in India WHAT kind of line you are using isnot known.thereis setting on FAX to detect fax tone. Switch phone Fax switch to AUTO.
Mar 18, 2008 | Uniden TRU8885-2 Cordless Phone
How does one get the handsets to record the new speed dial numbers on the base phone?
I'm pretty sure the speed dial numbers are programmed on a per-phone basis. Most people would not want changes on one phone's speed dial to effect the other phones. I know registering the handsets will not make a difference. If the cordless phone is working, it's registered to the base. This is required so your neighbor cannot buy the same phone model and use your phone line. In the old days cordless phones were permanently linked to one base but now you can get extra handsets on many systems and "register" the phone to work on your base.
Jul 06, 2007 | Uniden DCT-7488-2HS Digital Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
14 people viewed this question
jasbo
jasbo
