Question about Car Audio & Video
PEUGEOT 508 USB STICK WONT SEE ALL FOLDERS - Car Audio & Video
IBM Travelstar usb 2.0 - when connected to pc get error msg - problem with drive need to scan - WILL scanning ERASE FILES THAT ARE STORED ON THE usb drive
the scan is just a program reading the files and folders either in the computer or storage device
normally it is done by the security program ( windows fire wall) or what ever program you have installed
it reports on any problems found and waits for your decision
if you run a system check, that is different as it will rectify any program faults as it goes not files or folders
it is always advisable to scan usb sticks when installing as that is a favourite way that hackers get into a computer
although the usb stick may be in your control all the time , downloads from your own computer can transfer a problem via usb stick
As for your concern---scanning will not change any files or folders but will report on any faults to you
Dec 31, 2016 | IBM Computers & Internet
Usb does not work in Peugeot 508
unplug the usb stick and plug it into the usb slot.
Nov 14, 2013 | Computers & Internet
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
I have managed to get pictures from the memory stick unfortunately there are some pictures which are not in the memory stick yet i can still view them in my camera. How do i download them from the internal...
Go to Start/ My Computer/ and check the camera card (not stick which refers to an external USB memory) It will be there named D: or E: open all the folders there one by one - also folders witthin folders - the photos have to be there.
Dec 06, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Gears stick
If your car is a manual gear change, your clutch may need adjusting or repair or the gearbox oil may need changing.
If your car is an auto check to see if you are using the correct transmission fluid , Peugeot autos do not use normal ATF and will fail if the correct fluid is not used.
Hope this helps Marshall
May 26, 2010 | 1990 Peugeot 405
The problem is with my 1GB memory stick. I don't
Check your computer
with antivirus and antispyware program and format 1GB memory stick.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format 1GB memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 21, 2010 | Electronics - Others
PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Jun 28, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick
Format the Memory Stick via PSP.
Go to System Settings->Format Memory Stick
This process creates all folders that are supposed to be on your Memory Stick.
Feb 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
