Question about Konica Minolta bizhub Office Equipment & Supplies
"Original Left on Glass" when paper is put in auto feeder
  • Konica Minolta Master
  • 6,696 Answers
Well a model number would help of the copier
Posted on Jan 19, 2016
SOURCE: Black line on copy while using paper feeder
try cleaning the feeder glass
Posted on Dec 04, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Paper feed problem
Sound like something foreign is in paper path
Posted on Dec 24, 2007
SOURCE: keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Posted on Mar 14, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    SOURCE: Brother MFC 8840, Document Feeder is not workting
    ITS PROBABLE THAT A CONNECTOR CAME OUT.REMOVE BACK CORNER PANEL AT FEEDER CABLE TO CONFIRM.
    Posted on Sep 11, 2008
    Kyocera FS-6525MFP---printing with 2 thin black lines running the entire width of the paper. Where do I look to find the culprit?
    see if you have the lines if you make a copy without putting original in the auto doc feeder if so its either drum or fuser roller if not then clean the narrow piece of glass next to the copy glass use alcohol
    Mar 02, 2018 | Kyocera Office Equipment & Supplies
    Copying 8.5x8.5 original thru document feeder and it doesnt aal print
    Most copier has an APS (Auto Paper Selection) as default, 8.5 x8.5 is a square original, I would suggest you manually select the paper tray (e.g. Letter) first (this will temporary disable the APS for this session), then lay it down on the original glass, or ADF (Auto Document Feeder).
    If you do not disable APS, you will have paper jamming problem, you do not have 8.5 x8.5 is th paper tray, of course, you may try it feed from the by-pass tray, set the the paper size to 8.5 x8.5 or special size ....... Each manufacturer has a different name for the same function (terminology).
    Nov 12, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
    Black line going down page only when feeding paper through feeder
    There should be a thin piece of glass to the left of the big glass that you put the original to be copied on. Clean the small glass very well and try copying again. If there is a spot on the glass, it will show up on the copy as a line.
    Sep 06, 2013 | HP Officejet Pro 8600
    I have a brother mfc 240 printer. Lately whenever i use the auto feeder black vertical lines show up all over the paper. If i print by laying something on the glass it doesnt seem to do this. Also if i...
    When you use the feeder to scan, the original is scanned across a small strip of glass on the left side, rather than using the long platen glass to scan. If you're only getting lines when you use the feeder, there is dirt or white-out or some other substance built up on that **** glass. Wiping it down with a dry lint-free cloth should probably do the trick, but if the lines are still there you might want to use a damp cloth.
    Hope that helps!
    Jun 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
    How do I clean document feeder? It is putting
    If it is just puting lines on the copies ONLY when using the feeder here is all you need to do to clean that thoroughly.
    Get a phillips screw driver. Lift the document feeder, you will see the "seal glass" about 1 inch wide on the left side. Remove the 2 silver screws, One on each end. Lift that glass up and out. Lay it on a white piece of paper. Take some alcohol and a regular piece of copy paper and clean that until you see nothing on that glass by placing it against the white paper. Get every little speck off. Then put the glass back in.
    If you want to clean the entire scanner that is a different procedure all together. Let me know .
    Feb 10, 2010 | Xerox WorkCentre M20i All-In-One Laser...
    My printer says "close document feeder cover". I don't know where this is
    It is talking about the flap that is on the very top just above where one puts in an original to auto feed on to the glass, this access cover is required to be open and closed by the machine because it feels something is holding it open or its switch that tells it such is stuck. Maybe a jam from last original fed into it..
    The cover once open check around for paper fragment and inspect little levers that hang down, one is stuck or there is paper stuck in Document feeder
    I have found that often label bits, paper clips, punch bits and small corners of paper often get in the path, I use a piece of laminate cut so it has a v or a point and feed it in the document feeder, manually inserting it in the direction a piece of paper normal travels in it.
    Push it all the way threw not pulling back (bad for it) to do so poke the point threw, you will need the top cover open and lift off the glass, so you can grap the point and pull the laminate threw.
    Nov 04, 2009 | HP OfficeJet d145 InkJet Printer
    It works great in all aspects, but when I make a copy of something there is a black line about 2.5" from right side of paper (only when I use the auto feeder to copy) If I lift the lid and palce the paper...
    You need to lift the document feeder and clean the small **** exposure glass located to the left of the main exposure glass.Any foreign substance on this glass(ink, glue, correction fluid,etc.)will cause lines on copies when you use the feeder.
    Oct 08, 2009 | Samsung SCX-4725FN All-In-One Laser...
    When I feed pages through the automatic feeder, the copies come out with a streak on them. If I put them directly on the glass it doesn't happen. I have cleaned the platen glass with no result.??
    It is a cleaning issue. There is a piece of glass about an inch wide that is next to the platen glass or inside the auto document feeder that is probably dirty depending on your model. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
    Oct 03, 2009 | Canon imageCLASS D320 Digital Copier
    Two lines, one on each side of copies made from feeder and faxes
    Try cleaning the rollers inside the scanner including the glass inside and out with a soft damped cloth. Look also for a piece of paper, staple wires, paper clips or pencil lead jammed inside the rollers or somewhere in the corner.
    Also, look for a foreign object or substance on the cold cathode tube light and clean it. Try also cleaning the mirror.
    May 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Line down the middle of copies
    Clean the **** glass... usually a thin glass to the left.... check with a small flashlight, small blotch of ink or white-out can cause this... hope this helps.....
    May 06, 2009 | Toshiba Office Equipment & Supplies
    245 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    Ben
    Ben
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
