Question about Jenn-Air Freezer Jenn Air Clear Cube Ice Maker
Jenn-air model # JSD2789DES DOES NOT MAKE ICE AND IS ASKING FOR NEW FILTER
2 Suggested Answers
SOURCE: We have a Jenn-Air Refrigerator/Freezer
Check for blockage in the water line in the freezer. If so, defrost it. Might need a new water valve. Maybe a bad ice maker too.
Another possibility is that it's not cold enough in the freezer. Should be below +10F.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Posted on Jan 27, 2011
We have a Jenn-Air Refrigerator/Freezer (Model #JRSD226) and the ice maker has stopped working.
Jan 25, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Blades in my Jenn Air ice maker are not turning, ice maker no longer producing ice. Model JTB1988AE.
There may be some ice buld up blocking the lever from turning. A blow drymay be a quick fix. I can't see in there so just guessing. Please leave a good thumbs up for the effort. The Raz Shack
Mar 09, 2010 | Freezers
Doesn't make ice cubes. Water doesn't come in.
Hello it sounds like the timer on the ice maker may be the cause. If you open the freezer when the fan is off raise and lower the arm on the ice full shut off. listen for a faint clicking noise you wont hear if fan is going. If it does not click the problem is going to be in the actual switch. I have repaired several with this same problem with the switch but you would probably rather invest in a new ice maker or either buy some trays. As the ice makers can cost up to 200 dollars in some models. The only other thing to check is if the water line is bent or crimped off.
Jan 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
48 people viewed this question
Top Jenn-Air Freezers Experts
AJMAL KHAN
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Jenn-Air Freezer Expert? Answer questions, earn points and help others
