Question about Russell Hobbs Coffee Makers & Espresso Machines
The water won't heat, doesn't go through the system
Microwave won't heat
Sounds like the magnetron has failed. :(
May 18, 2012 | GE Microwave Ovens
Whirlpool built in dishwasher DU840SWKQO
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 22, 2011 | Whirlpool Dishwashers
I have a 04 Chrysler sebring and the engine is over heating, the coolant container be bubbling, and the heat won't come on all of the sudden I just put a water pump on.
you might want to change the thermostat and make sure there is no air in the system,make sure all the air is properly bleed out of the cooling system.also make sure that the cooling fan at the rad is working properly.if this doesn`t correct this have a combustion gas test done on the cooling system.
Nov 01, 2011 | 2004 Chrysler Sebring
There is a problem with the coolant. I have to add quite a bit every week. I did some researching and it sounded like the heating core, but when i pulled up the carpet, there was no wetness. There is...
For starters there is no problem with your coolant. If your car doesn't overheat, no problem. There is a problem with your coolant system if you suspect a leak. You won't find water on the carpet where your heater is because it is in a box with a drain that goes outside the car. If there is a hissing noise coming from the radiator cap, likely it needs replaced as it is not keeping the water pressure in. Replace it.
Jun 05, 2011 | 1998 Volvo S70
I don't have a problem, just a question. I recently purchased a home with a GE Smartwater softening system installed Model GXSF23Z01. What do I need to do to maintain this system. Does it require salt?...
Check the time of day, and make sure it's accuate. Reset if necessary. Add salt if it's low. It's always best to let the salt level run low (about 1-2") so it doesn't mush. Only add 80-100 lbs at a time for best results. This particular softener doesn't keep a water level in the tank, so you won't see any water in the salt area. If there is standing water in the salt area, that could mean it's not working the way it should. Here is a link to the owners manual. It's in PDF format
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003674144.PDF
May 14, 2011 | General Electric GE SmartWater Household...
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Russell Hobbs Coffee Makers & Espresso Machines Experts
Paul Bade
No_ky
ray gallant
Are you a Russell Hobbs Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
