Question about Dell Office Equipment & Supplies
Dell 3115 how to reset fuser count - Dell Office Equipment & Supplies
3 Suggested Answers
SOURCE: How do you reset the fuser count of a Brother HL4070CDW?
If reset parts is life not available after OK > Machine Info > Reset Parts Life (if it only shows "Parts Life", then do this:
Press GO and UP arrow at SAME TIME > Reset parts life
Scroll up or down to choose which part to reset
Press OK and confirm
Posted on Apr 21, 2011
  • 157 Answers
SOURCE: My Samsung CLX-6210FX blinks and call replace
You have to reset fuser from settings option.
Posted on Jun 28, 2011
Reset fuser message on dell 5130
Johnathan, Reset the life counter:
  1. Enter the printer's tech mode by quickly pressing the sequence of keys Menu > Up Arrow > Left Arrow > Tick > Right Arrow > Cancel > Menu. If tech mode does not appear, Re do key sequence again as quickly as possible. A delay in pressing the keys will stop the menu from opening.
  2. Select tech menu , data setup, Clear fuser count.
  3. Restart the printer.
  4. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Knowledge Base
Replacing the Fuser on Dell 5130cdn Laser Printer
https://www.sosnfl.com/wp-content/uploads/2014/12/Dell-5130cdn-Users-Guide.pdf
Apr 09, 2016 | Dell 5130cdn Color Laser Printer
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
How to replace dell 1250c fuser?
To reset the life counter:
  1. Enter the printer's Tech Mode by quickly pressing the sequence of keys Menu > Up Arrow > Left Arrow > Tick > Right Arrow > Cancel > Menu. If Tech Mode doesn't appear, press the key sequence again as quickly as possible. A delay in pressing the keys will stop the menu from opening.
  2. Select Tech Menu > Data Setup > Clear Fuser Count.
Read More... Replace the fuser and reset the life counter on Dell 5330dn laser...
And Dell Printer Support
Thanks,
Jul 30, 2014 | Dell Office Equipment & Supplies
Removal of paper stuck in a dell 3115 fuser?
It's best to remove the fuser to get access to it. This video will show you how to remove it, and which levers to move to release tension in the pinch roller to clear the jam http://www.youtube.com/watch?v=UjyggtF8d1k After you remove the jam make sure to do a close inspection on the internal roller (use a flashlight). You're looking for any scratches or "dents" in the colored roller (sometimes a deep red/brown color sometimes blue) if there are scratches you are probably going to have to replace the fuser. The imperfections on the fuser roller will show up on your printed pages. If you do need a new fuser you can find them for $160, or the entire rebuild maintenance kit for $375 http://www.fastprinters.com/productdetails.asp?PRODUCT_ID=DELL-UG190
Dec 19, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Is there any way to reset the fuser on the dell 3110/3115?
You might try taking out the fuser and replacing it. First of all, I'd let the machine sit for at least 30 minutes if you've recently printed anything, as it needs time to cool down. After that, press the button on the upper right side of the device to release the cover. Then release the chute gate to its upright position. Release the two tabs on each side of the fuser to unlock the unit and slowly pull it out of the machine. To replace it, push the fuser connectors into the slot firmly to make sure it is properly seated . Lastly, close both of the levers you opened earlier to remove the fuser. Make sure the chute is also lowered to the position it was in before. You can then close the front cover. Hopefully that will resolve all your printer issues. If not, you may need to contact a support technician. Good luck!
May 11, 2012 | Dell 3110cn Laser Printer
How would you reset the fuser life for Dell 5330dn printer?
power on the printer
Wait for ready mode.
Press Menu -> Up -> Left -> Ok -> Right ->Cancel ->Menu
This will bring you the the Tech Menu, select it.
navigate to Data Setup (Down arrow) and press check
navigate to Clear Fuser Count and press check
Power on and off
Print a config from the reports menu to check if the fuser count 0.
keep in mind you have to press the keys (for getting tech menu) really quick, try not to look the display but the keys (the menu, up, left, ok, right, cancel, menu combination i mean)
good luck
Sep 20, 2011 | Dell 5330dn Laser Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
Replaced fuser on Dell 5110cn printer. How do I reset?
There is no way to reset the Dell 5110 fuser 310-8729 (also known as TD218 and other numbers)
The connector in the fuser holds the page count. If you printed 200 pages on a fuser and moved it to another printer, you'd see it follow the fuser.
You may have put a non-compatible fuser, or it may be depleted already, or there is a circuit board problem.
Whit
Item, Inc.
Sep 17, 2010 | Dell 5110cn Laser Printer
How do you reset the fuser count on a hp4700
The fusers for this particular printer have the reset technology embedded in them. There is no menu option to reset the maintenance count. If upon installing the new fuser it hasn't reset the count itself, you need to contact your supplier about getting a replacement.
Aug 20, 2010 | HP Office Equipment & Supplies
DELL W5300 PRINTER - GETTING THE MAINTENANCE COUNT
It is like your oil light coming on. It means the printer has reached its pages count where they recommend changing the maint kit. (usually new fuser / rollers). If print quality good - let it go - it will work for another 10,000 pages or so. If print quality bad (streaks and rough spots) it needs a new fuser. After replacing the kit you reset the count to zero and it start counting again.
Feb 27, 2009 | Office Equipment & Supplies
203 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
