Not working 3tonn ac out door one fan motor not working
    Master:
  • 571 Answers
Check the capacitor.
Posted on Feb 21, 2014
Pontiac g6 2006 heater/ac fan doesnt work on #3 speed setting, fan made squealing bearing noise for a while but quit, also inside/outsied air vent switch vent makes clicking noise when set to outside air
you will need to replace the blower motor as it has probably siezed going by the squealing noise you say you heard.i`m assuming this has more than 3 speeds for the fan motor.if it wasn`t working on one speed then you probably have a bad blower motor resistor that will need to be replaced as well so you will have all fan speeds.this is located in the air duct housing near the blower motor and will have about 6 wires on it.some of these on under the hood on the firewall anywhere from the passenger side to the center of the firewall.not sure about the vent switch.if the vent switch is moving the doors and you hear a clicking then you may have a vent door problem that the door pivot is worn.
Nov 01, 2013 | 2006 Pontiac G6
Ac/heater fan doesn't work
According to my wiring diagram, the blue and white wire from the blower motor gets power from the key switch. The fan switch and resistor grounds the motor.
No blower fuse is listed.
Feb 03, 2013 | 1988 Honda Accord 4 Door
Rheem rrka a030jk08e outside ac fan does not work
If only fan not working, replace capacitor and try. Still problem, you have to replace fan motor itself.
If you mean outside unit not working, check input at thwe out door. If not check your PCB. Repair it.
Sep 06, 2012 | Heating & Cooling
No fan operation on867819221 ac
It can be issue with relay or wiring of the fan causing the problem.
Check the help links.Click the link below:---
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater AC or defroster fan not working on KIA? http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
Where is A/C CONDENSER FAN MOTOR RELAY Located? http://repairhelpcenter.blogspot.com/2011/11/where-is-ac-condenser-fan-motor-relay.html
How to Remove Fan Clutch ?
http://technoanswers.blogspot.in/2012/04/how-to-remove-fan-clutch-on-2005-gmc.html
This will help.
Thanks.
Jul 17, 2012 | Cars & Trucks
AC will not cool
There are a lot of reasons ,if the ac line,the large one,going into the firewall to the inside of the car,is cold,then there is a temp door actuator motor not working,if the ac compressor is turning,then this is a possibility,but it can just be low,or out of freon also.
Jul 05, 2010 | 2002 Buick Rendezvous
Ac/heater works but doesn't blow air at any speed
Yes. It could be your motor. If there is voltage or your hear the motor running then it could be a vent door not working. There is also the switch and a blower motor resistor that you can check. Hope this helps.
May 17, 2010 | 1997 Buick LeSabre
2000 jimmy a/c blows hot computer controlled a/c button light was blue when working now yellow and blowing hot just charged system no change
check to see if ac compressor is turning ,if so look to see if cooling fan/fans are working if not check fuses,and cooling fan relays/if ac is turning and cooling fan/fans are working ,need to put gauges on ac system and check pressures ,if normal ,and ac low side pipe/lines/hoses are cols then it is ur actuator motor for the temp door that is not working
Jul 08, 2009 | 2000 GMC Jimmy
AC and fan and passenger side power window will not work
if the fuse or a relay were the problem no window would work, u need to replace the power window motor inside the door.
Jun 18, 2009 | 1998 Ford Econoline
AC/heat/defrost functions don't work
there is a blend door and a selector door in the HVAC system. These are run by vacuum or servo motors. Sounds like this little motor is your problem. Hope this helps you.
Jan 18, 2009 | 1997 Ford Thunderbird LX
Electrical problems with trunk gas door and ac
the first problem with you fuel door is most likely the rear actuating motor or cable. remove the right rear trunk lining, and loosen the 2 silver phillips head screws, and remove the actuating motor. i would suggest replacing both the motor and the cable, as both of these parts have superceeded to a new improved part. the AC problem is caused by a faulty fan control unit. this part not only receives the switch signal and processes the information to control the compressor, but also controls the fans, their speed, the compressor,and the hi/lo pressure switch. both of these parts a a common problem for the beetle.
Jul 04, 2008 | 2000 Volkswagen Jetta TDI
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
