Question about Cameras
How to set up time and date in yokatta DX-6 - Cameras
How do i set the time on a pantech p5000?
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauderâ„¢ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Nov 01, 2015 | Pantech Cell Phones
Release Date Check for fifa 12
North American Release Date was 27 September 27, 2011. European release date was September 29-30, 2011.
Minimum Requirements
Celeron E1200 Dual-Core 1.6GHz
Athlon 64 X2 Dual Core 3600+
GeForce 6600
Radeon HD 2400 Pro
1 GB RAM
Win Xp 32
DX 9
6 GB
Recommended Requirements
Core 2 Duo E6600 2.4GHz
Athlon 64 X2 Dual Core 5600+
GeForce 8800 GS
Radeon HD 2900 XT 512MB
2 GB
Win Xp 32
DX 9
6 GB
Jun 13, 2012 | Electronic Arts Rail Simulator for...
Kodak DX 4530 worked well until I deleted all internal photos. Now when I turn camera on and set to auto the camera goes to date and time set. Once I set the correct date and time and press OK, the camera...
Do yourself a favor and get a memory card....they're not expensive and it will help you to avoid all the problems that the internal memory causes.
Aug 14, 2011 | Cameras
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
HOW TO DISPLAY DATE
1) Open Settings Menu
2) Select Initial Settings
3) Select Time and Date
4) if you see the "Auto Update on", press right arrow , it turns to Off.
5) Then select Date and set the appropriate date and format.
6) Press OK
7) Then just press the red button or cancel.
now the cell should display the date..
Jul 20, 2010 | Motorola Mobility L6 Cellular Phone
Set date and time- lost our manual!
Press
Function
71
set
key in date and military time
set
stop
Oct 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Clock radio, small
This little guy has the most complicated date setting procedure I have ever seen! From the manual: "Manual Time and Date Settings 1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing. 2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator. 3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting to lock into place. 4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year. 5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the 4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day. 6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place." You can download the manual from the link below: http://www.timexaudio.com/pdf/T307_IB56281_07.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 24, 2007 | Timex (T307S) Clock Radio
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
