Question about HP COLOUR LASERJET CP4525DN Printer
Black line thick black line down one side of page
SOURCE: Black lines on the right side
The vertical black line at the right-hand side of the page when the printed document includes an image is a problem with all currently available HP Laserjet 1018, 1020 and 1022 drivers. While waiting for HP to fix the problem (they haven't even acknowledged it yet in their webpage) you can bypass it thus: a) Click on the 'Properties' button. b) Click on 'Finishing' and select 'FastRes1200' (this makes the line narrower). c) Click on 'Basics' and select 'Rotated', i.e. printing the page from bottom to top (this elliminates the line completely, in combination with 'b' above). This is a home-made solution I found after numerous trial-and-error attempts and having downloaded several drivers from the web. As a token respect to all of us who have paid money to buy these printers, I hope HP will soon recognize and solve the problem.
Posted on Sep 25, 2007
  • 2072 Answers
SOURCE: vertical black line down right side
Did you carefully inspect all through the paper path for some fuzz, or a small piece of paper smearing the print?
The other issue would be the fuser. Do you see any reprinting of images or letters in that area?
What you can do is set the machine to print 2 or more pages and open a cover or turn off the power to jam the prints in the machine. See if the line is on the drum or not. If not then you have a fuser roller issue which would require replacing the fuser.
Posted on Mar 06, 2008
SOURCE: light grey vertical line
I believe there are 3 possible causes for this issue; toner drum, fuser or transfer roller - more than likely I would dismantle the printer and check for lines on the fuser. But just in case remove the toner and carefully release the flap to reveal the toner drum - if that is scored and the lines correspond to those on the print-out thats the cause.
Rgds Colin
Posted on Jan 03, 2009
SOURCE: vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Posted on Jan 23, 2009
Wiired
  • 122 Answers
SOURCE: Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Posted on Jun 22, 2009
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Printing black thick line down left hand side of the page
IF THE LINE IS CONTINUOS ON ALL PAGES THE DRUM OR ROLLER IS BEEN DAMAGED.
Feb 03, 2010 | HP LaserJet 1010 Printer
Thick black lines (of toner down each side of printed page
There are problem in your toner, in toner there is a drum which are scratched, you have to replace this drum.
Problem will be resolve.
Regards
Ashly
Feb 02, 2010 | Samsung SCX-4100 All-In-One Laser Printer
LARGE HORIZONTAL BLACK LINE- PSC 1610 PRINTER COPIES
NO, I DID NOT GET IT FIXED. YOU TOLD ME TO SCAN SOMETHING TO THE PC, WHICH I DID. SENT PAGE TO MICROSOFT WORD AND THE BLACK LINE WAS STILL THERE. I BELIEVE MY SOLUTION IS TO JUNK THIS THING AND BUY ANOTHER.
Jan 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Feb 02, 2009 | Brother MFC-7820N Printer
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Black lines down page
It must be the black pcu , the cleaning blade picks up dirt and causes these lines , it can also be the black developer giving you trouble , if you want be very carefull aand strip the pcu open you will see the lines only on the inside and not from outside , then you will know if it is developer or the cleaning blade
Oct 24, 2007 | Ricoh CL4000DN Laser Printer
HP COLOUR LASERJET CP4525DN Printer Logo
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
