Question about JVC KD-BT1 CD-Receiver CD Player
Face plate won't stay on
I can not get my face plate to stay on. It won't latch on and it doesn't look like it's missing anything. My son put it in my truck but it was in his truck and it was complete but whe. He put it in my truck it won't stay in place. Can u please help me.
GARYDALE
  • 15 Answers
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Posted on Sep 25, 2006
merle840
  • 113 Answers
SOURCE: cd player broken
unplug the radio from its harness for about a minute then plug it back in try the radio again if you still get that squeal-it is possible that either one of your speakers is shorted or your wiring has a problem- cleaning will not help this problem!
Posted on Mar 27, 2008
proton77
  • 1183 Answers
Thanks for the description of your problem. At the face of it , it looks like the problem is only the face plate. Coz the unit lights up fine and there are no blown fuses. I recommend replacing the face plate first and checking. If the that not working , we have to open the unit and check internal connections.
Also do check all your relay cables, just to make sure you are getting proper current to the unit.
Thanks
Proton
Posted on Jun 18, 2008
zappanut
  • 959 Answers
SOURCE: the face plate of the jvc car stereo doesn't stay tight and radio
I suggest some two sided sticky tape. Carpet tape , I thnk it's called.
If you don't plan on ever removing the face again...°¿°
Posted on Nov 18, 2008
FixMyConsole
  • 174 Answers
SOURCE: I need to buy the face plate only because the original got stolen
Call 0121 5206666 or google A.E.L they are based by us, and as a former engineer repairing the stereo's i can vouch for their quality and speed.
Posted on May 24, 2009
My sons Chevy half ton rear end locks up was told limited slip disk any ideas or help be appreciated
you can try taking the inspection plate off and see if there is any metal particles on it or take face plate off and have a look see and check if anything broken. best case scenario reseal diff plate and put new clean fluid and go from there worse case grab a used rear end from a wrecker
Sep 18, 2013 | Chevrolet Cars & Trucks
HOW TO TAKE OFF FACE PLATE GATEWAY FX6840-03e
Once you remove the case you will normally see some latches that are the same color as the face plate running along the side of the metal part of the computer. Just push the latches so that they don't catch then remove the face plate.
Apr 02, 2012 | Gateway FX6840-03e PT.GAT02.023...
I went over a pot hole and my face plate popped off and now it won't stay on what should I do ?
i suggest first reading the directions to make sure you are connecting the face plate correctly. or you could gorilla glue it on just to make sure the connections from the face plate and radio are connected before binding the two
May 05, 2011 | JVC Car Audio & Video
How to change from latch with face plate to drive in latch
How do I mount the Face Plate on the Latch?
Insert the latch into the faceplate opening, ensuring that the sides of the faceplate line up with the flat surface on the latch collar. Push flush with the drive-in collar. Then grasp the faceplate in one hand and the latch in the other hand and rotate the faceplate clockwise to snap in to the collar.
Nov 24, 2010 | Weiser Lock Powerbolt 1000 Lock
JVC KW-NX 7000, the spring loaded latch for the detachable face is broken so the face plate will not stay on therefore I cannot use my unit. Can I buy a new latch for this and if so where or do I have to...
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
Oct 18, 2010 | JVC KW-NX7000 Car GPS Receiver
Freezes while i press open
first check all of your power and ground connections and be sure your battery is good then try the small reset button on the front face. if that does not work you may need a new flexible ribbon cable that you can find on ebay cheap.
Nov 25, 2008 | Pioneer DEH-P9600MP CD Player
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Face plate is black
The 12 volts lights that illuminate the face plate are burnt inside and should be replace. It's a common failure on any face plate.
May 04, 2008 | Panasonic CQ-DF802U CD Player
Psp anolog button faulty?
You just remove the face plate again and check it now your PSP is working OK if so there is some misalignment while placing the face plate on PSP and suppose your fault still remains same without face plate also then there is a possibility of Analogue button is being damaged which should be changed.
Feb 27, 2008 | Sony PlayStation Portable (PSP) Console
JVC KD-BT1 CD-Receiver CD Player Logo
26 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
