Question about Video Cameras
Anti shake failed
When zoomis on maximum picture anti shake fails and the image jumps
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
You rely shouldn't use the zoom to much as you will loose any quality that you might have try to add any effects on the video editing softwear that you use .
Posted on Feb 11, 2014
Visor view
Some of ALPHA DLSR are prone to have such problems on antishake mechanicsm. I stucks and fails. You start to see a black line or twisted view instead to correct image seen on optical visor. You either need somebody to service it or you need to remove ccd board and fix the shaking mechanism by trial and error. Fixing means really fixing it to surface that it wont move anymore. Since this will allow framing corect you will loose anti shake function. though situation. Check the link. you are not alone.
a200 sensor shake stabilization malfunction dropped camera
Apr 02, 2014 | Sony Alpha DSLR-A200 Digital Camera
Tv picture shaking and losing images and auto turn off then on then off again.
If this is a Toshiba the hypermodule likely failed and needs to be repaired or replaced. You can get kits from Ebay from sites like www.TvRepairKits.com
May 25, 2013 | Televison & Video
The images that I take are blurred
On almost all newer cameras there is an anti-shake feature. AND it is almost always turned off by default. Go through your camera menus and look for anti blurr or anti shake, the icon is usually a hand or person with lines "moving" outside it (to represent shaking). Good Luck!
Nov 10, 2009 | Canon Cameras
Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
Oct 30, 2009 | Audio Players & Recorders
My Sony DSC T70 shakes & vibrates
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Aug 25, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vibration of camera
Jumping
2001 Honda Odyssey 3000cc engine gave me the "shakes". Turns out one of the Ignition Coils failed rendering the spark plug useless. Change with part number 30520-p8e-a01and now runs normally.
Aug 11, 2008 | 2003 Honda Odyssey
My Monolta Dynax 5D judders on startup, then the shake reduction display flashes then it wont take pictures or turn off. It just shows br1 in viewfinder display
It would appear from other sites and users that the anti-shake mech has failed and the cost to repair outweighs the value so I will stick with my SonyA700, sell the lenses and filters I dont need and scrap the body. Thanks for the reply.
Aug 07, 2008 | Konica Minolta Dynax 5D / Maxxum 5D...
In Anti-Shake mode, what is the maximum shutter speed with Hand-held shooting?
Though there is personal difference and position of zoom, however 1/25 s. would be recorded with sharp image as lowest speed.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Video Cameras Logo
37 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
