Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Error a000001c enabling scanner - Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Unable to obtain authentication input/output error has occurred. Error while loading applet Module is not registered.
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.
This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks
The Rule is:Help others without charge :)
Jan 10, 2011 | DigitalPersona UareU 4500 Fingerprint...
Hi, my terminal Motorola MC3190 doesn't want to enable scanner and i really don't know why.... There is an error code A0000032 with message: "CANNNOT ENABLE SCANNER"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software.
Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Nov 09, 2010 | Zebra Symbol Technologies MC909X-G Series...
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
I am getting this error on my mc9090 scanner: " Error A000000B enabling scanner. Scanner support has been disabled"
In most cases you find that the flex that connects the cpu and the scan engine is faulty or out of alignment. Try to cold boot the device or if it's out of warranty you can open it and realign the flex. Other than that you have to send it for repairs.
May 17, 2010 | Zebra Symbol Technologies MC909X-G Series...
Looks like laser head does not work and cannot be recognizied by scanner.
Sep 10, 2009 | Zebra Symbol Technologies MC909X-G Series...
Scanner problems
Don't know if this helps but it's from the manual on lexmarks website.
Scanner Connection error 1 Disconnect the USB cable from the printer. 2 Reconnect the USB cable. 3 Turn the printer off. 4 Unplug the printer. 5 Plug the printer into an electrical outlet. 6 Turn the printer on. 7 Restart the computer.
Weird order of doing things but maybe that's what you have to do to get the scanner enabled again. Give it a try and see what happens.
Jan 04, 2009 | Lexmark X73 All-In-One InkJet Printer
Error message: enable to connect with scanner
Part of the problem may be that Visioneer did not develop any drivers for Vista considering that the 5800 had reached E-O-L.
Sep 25, 2008 | Visioneer OneTouch 5800 Flatbed Scanner
Error message
Get another scanner. Check whether the lock has not been enabled at the bottom of the scanner. This has happened with me as well and a known Visioneer problem.
Sep 19, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
60 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
