Question about Compaq Evo D500 PC Desktop
I have a Maxtor 20GB Hard Disk which when connected to a computer the BIOS is able to read it but the problem is the HD only shows ZERO GB(its empty).Can this problem be fixed in order to make it show 20GB or is it dead.
    Problem Solver:
  • 18 Answers
Computer sees the drive. That is important. I'm assuming this uses a standard IDE cable and the drive isn't physically damaged. Make sure it is the only drive connected and it is the Master. Try flipping the cable if you have checked that the connection has a snug fit. Put the connector that you had the hard drive originally on and place it on the motherboard and the connection that the motherboard had insert it in the hard drive.Or better yet try a new cable. IDE cables have a tendency to fail. You could also try some recovery software. Maxtor is now part of Seagate so you can try here:
http://www.seagate.com/support/downloads/
If you absolutely have to get data off this drive and you are desperate, then you could try the freezer trick. Put a dry towel and hard drive in the freezer for an hour or 2. Take the hard drive out and wrap it with the cold dry towel. That is to try and minimize any condensation build up. Plug in the hard drive and see if it works. This could potentially kill the hard drive but I have recovered data using this method before. If this works for you do not depend on this drive anymore. Good luck.
Posted on Feb 11, 2014
2 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: entering bios
the bios wont support anything higher. Go the the website and flash it with the new bios download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&docname=c00004461&dlc=&product=92867&lang=&
Posted on Jun 09, 2008
How do i change it back to 20gb
> how do I change it back to 20GB.
What is it currently showing as? Zero?
Any 20GB disk-drive is probably _many_ years out-of-warranty.
Take a sledge-hammer to it, so that NOBODY can possibly read your data,
and then responsibly recycle the disk-drive.
Spend $50 to buy a new disk-drive with TWENTY times the capacity of your "antique" drive.
Nov 03, 2010 | Seagate U6 (ST320410A) 20 GB Hard Drive
My Maxtor 200GB external HD is not showing up on my Mac G4. I've tried USB & Firewire connections. Restarted the Maxtor then computer. Restarted computer, then Maxtor No good. Thanks for your...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 26, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
My maxtor 500GB sata hd gives zero number of cylinders
go to the bios system
select booting device
choose hard disk
save & exit
thank you
Jan 15, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from www.thefreecountry.com/security/securedelete.shtml
Jul 21, 2008 | Maxtor Hard Drive
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Nov 12, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Compaq Evo D500 PC Desktop Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
