Question about Dayton Electric Heater
Wiring diagram for dayton 2yu36
Is the limit off the contactor suppose to be open or closed?
2 Suggested Answers
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
I have a colman furnace one element stays on constantly can you tell me why
Furnace is the term we use for a gas system. I'm assuming you have an electric "air handler"(unit), and or has 1 element staying on, glowing red, and cycling on a limit. These elements are controlled by "heat sequencers", heat relays, and some older units used heat contactor's. This "switch" is stuck closed & must be replaced. I've also seen a direct short at the element itself, where the element has come apart, and a part of that element had touched ground. This completed the circuit and allowed the element the energize. Hope this helps! Its probably a stuck (closed), switch that's supposed to open when the tatat is satisfied.
Feb 21, 2017 | Heating & Cooling
My nice sliding gate only closes with the fob and will not open
There are several possible causes, but the first to check is the limit switches. When the gate opens, it is supposed to trip a limit switch that tells the mechanism that the gate is fully open. If the switch is not tripped, it will not respond properly to a command to close. It may think the gate is running into an obstruction and then just shuts down.
Feb 02, 2015 | Nice Robuskit Slide Gate Operator Motor...
LARRS LX 400N It will not start the ignition sequence. Flame switch is OK. Limit switch mounted on the right outside of the upper cabinet is OK. Have low voltage. The pressure switch is open (is there...
"The pressure switch is open (is there supposed to be water pressure on the pressure switch so that it will close?)"
All switches need to be closed in order for this heater to start.
If you know you have good water flow (at least 50gpm) and your finding the pressure switch still open, it is either failed or clogged. Clean or replace the pressure switch.
Apr 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How to fix/close a sunroof/moonroof stuck all the way open?
I have a 2003 4runner limited and the moonroof is jammed open.
I took it to the Toyota Dealer and they said they didn't know how to get it closed and charged me $44 just for driving it into the shop. Help it is suppose to rain tomorrow.
Oct 31, 2010 | 2005 Mazda 6
My Frymaster is beeping and coming up with a message HOT on the screen
Temp got to hot and shut down high limit. Also check for a broken wire to high limit
Sep 17, 2009 | Frymaster Dean H22 Deep Fryer
Ac wont shut off rheem gas pack unit is old
Turn off the power to your condensing unit.
Open the service control panel.
Look at the contactor and take one of the low voltage wires off of it.
If the contactor stays closed, replace the contactor. Even if you clean the contacts it will stick again.
If the contactor opens replace the wire and check the thermostat to see if it is operating correctly.
Jun 19, 2009 | Weather King 12AJA4801AH Air Conditioner
Electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Dec 07, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Contactor for La Pavoni Pub 2 espresso machine
1>Tom you must pay atention on electrical suply if coil of contactor, your contactor gets suply of electric wich passes through the contactor.
2>please go back to contactor and pay atention to coil suply you must have mistaken there something.
3> if it isnt visible than study the old contactor, was he 3 closed 1 open contact or 4 closed???? it can be that too, the contactor could not be with the same function.
Nov 18, 2008 | La Pavoni Pub M1 Espresso Machine
Compresser will not quit running
Turn your thermostat off, if still running ,then the contactor is stuck in close or run position, the thermostat controls the open & close of the contactor coil.. Replace the 24volt contactor on the outside unit and your problem is solved!
Sep 04, 2008 | Heating & Cooling
Goodman cetral air system brand new contactor hums but it will not switch on
That's what contactors are supposed to do, but they are supposed to turn the air conditioner on because the thermostat activates them, not your finger. Be very careful about sticking your finger in there.
Jul 22, 2008 | Goodman CLQ36AR49 Air Conditioner
Dayton Electric Heater Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
