Question about Vacuums
Bissell 27FG no scution and does not spray water
Need service manual for this model to trouble shoot if hose has become disconnected or needs to be replaced.
4 Suggested Answers
  • 272 Answers
SOURCE: Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
The 7920 is a 220 volt version of the 7901. I found a shop in New Zealand of all places that has service manuals on line. They are sort of picture books, but using them has saved me a lot of money as it makes repairing much easier. Here's the link you'll need. Good luck. If you need any more help, just add a comment to your post and it will go to my e-mail and let me know. The heads you clean are just the outlet spray heads when they get gunky.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Looks like you already have the USELESS Bissell advice list!
Posted on Jun 03, 2009
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: bissell 7901 proheat service manual
I took apart the cleaner to clean the parts that were dirty and I can't seem to put the roller back in. Any suggestions
Posted on Sep 01, 2008
How to trouble shoot and repair at home Bissell proheat 2X water will not spray from floor nozzel ?
Check your User's Guide. Cleaning the filters may do the trick. Contact Bissell Consumer Care at 1-800-237-7691
Sep 17, 2014 | Bissell Vacuums
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel cleaner won't stop spraying water
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
May 08, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Won't spray
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Mar 10, 2009 | Bissell 9200 Upright Vacuum
No cleaner or water will squirt out when I am shampooing. Yes, I have plenty of water, cleaner, power and set on floor cleaning bissell proheater 2X
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=556844
Posted by sherski3 on Apr 29, 2008
No cleaner or water will squirt out when I am shampooing. Yes, I have plenty of water, cleaner, power and set on floor cleaning Bissell proheater 2X
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Bissell 9500 ProHeat 2X Clean Shot Upright
This could be that you have a defective water valve assm below the water tank or the trigger assm is not working properly or not connected. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owners manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1698 PowerSteamer ProHeat Upright will not work. The brushes spin, the soap comes out, but no water is getting to the carpet.
You may try the trigger assembly may not be releasing the water , your brushes spin and the soap comes out but no water – it may have come unhooked or broken, also the water line could be plugged, clogged or pinched and not releasing water to the brushes -- you may try the owners manual for the trouble shooting for the item or check the Bissell website listed below or the customer service phone number of 1-800-237-7691 – the website has a list of trouble shooting listed right on the website I you enter the Model number and hit trouble shooting
(800) 237-7691
Hours:
Apr 15, 2008 | Vacuums
No water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=467200
No water
Posted by Emma Ann on Mar 25, 2008
My Bissell ProHeat 2x and it's not spraying any water out.
Don – The Vac Man
Go Ahead. Use Us.
Mar 25, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
