When I turn it on it does this 0 p how do I remove the p Sharp el-531x
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
You're apparently in the pental mode. To get out, press 2ndF -DEC.
Posted on Feb 11, 2014
  • 9 Answers
SOURCE: how to use sharp EL-531x calculater
http://sharpdirect.net.au/cms/products/6001/downloads/EL531XHWH_operation_manual.pdf
Posted on Dec 09, 2012
  • 7993 Answers
SOURCE: EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
Posted on Feb 24, 2013
  • 7993 Answers
SOURCE: sharp advanced EL-531x how to input number after number for stats
First you have to set the calculator in STAT mode, presumably Standard Deviation or SD. The display should show a STAT annoucer to the top. To enter values use the key M+ (or the key next to which is marked DATA. The screen displays the number of data values entered so far.
To get the statistics you must use the keys marked with x bar, n, Sigma x, etc.
Posted on Mar 02, 2013
  • 7993 Answers
SOURCE: I have a possible glitch on the Sharp EL-531X
I doubt that it has a glitch. Although possible, it is not very probable. Try to use the calculator correctly.
Follow the algebraic logic.
If you did not input any value the answer memory contains the value 0.
When you press (+/-) followed by [=] it takes the value in answer memory and negates it, thus giving you (-0).
Adopt a consistent way of inputting numbers, namely always enter the negation sign before the number that is negated. The calculator will enclose the negated number between parentheses, which prevents may errors. Too bad this feature has not been kept in more recent calculators by Sharp.
Posted on Dec 04, 2013
  • 7993 Answers
SOURCE: I have a sharp EL-531X calculator and I don't know
Use the Alpha keyboard to enter the left side of your equation. While equation is still on command line, activate the SOLVE application (Math). Enter a first guess, the increment and press =.
Press = to repeat the solution for the next root.
To help you practice, one root is negative and near -2, the second is positive and about 5.5.
Posted on Jan 20, 2014
How do I Remove stat
You STAT is the mode where you can do all your statistical calculations. To change between Normal mode and STAT mode press the MODE button (just below ON) and choose 0 for Normal.
May 30, 2014 | Sharp el-531x scientific calculator
Turn off the fix mode
Press SETUP and choose 0 for FSE. Then choose 3 for Norm 1. This will put the calculator back to the original setting.
Mar 20, 2014 | Sharp el-531x scientific calculator
All my answers come in decimals on my sharp el-531x and i want to turn it to normal
Press the SETUP key, press 0 for FSE, press the down arrow key, and choose 3 for norm 1. The calculator should return to normal. If all else fails, there is a reset button on the back.
Dec 08, 2013 | Sharp el-531x scientific calculator
Negative number
Use the "(-)" key, located on the bottom row of the keyboard, between the "0" and "=" keys.
Sep 30, 2013 | Sharp el-531x scientific calculator
Feb 21, 2013 | Sharp el-531x scientific calculator
EL-531X I NEED TO GET IT TO QUITE ROUNDING MY ANSWER
Hi Jennifer,
This may be because of your settings. To change them press SET UP, then select 0 for FSE. Press the down arrow and choose 3 for NORM1 - the calculator should now stop rounding off your answers.
Sep 25, 2012 | Sharp El-531x Scientific Calculator Green...
15 people viewed this question
jasbo
jasbo
