Question about Water Filters & Coolers
How do you put a vitality little luxury water cooling machine together
2 Suggested Answers
silawrence
  • 906 Answers
SOURCE: Why is my Little Luxury Water Cooler not cooling the water - it is switched on but blue light not coming on and water not cold
Yeah... most likely the cooling gas has leaked out. to repair it cost more than buying a new unit.
Posted on Jan 13, 2015
Write about the Graz Messe luxury villa in Goa?
There are many villas in Goa from which one of the best Luxury Goa Villas is Graz Messe villa which is a private villa with 1 bedroom and 1 bathroom and it is located near the coastline of the sea.
This villa is ideal for couples and it is equipped with a private bathroom with hot water and air conditioning which provides a comfortable coolness in the house. It has 2 large private swimming pools.
Oct 13, 2017 | Coffee Makers & Espresso Machines
Need a bobbin diagram for elba tx electronic so I can put it back together
It would probably be better to just purchase a brand new bobbin case. A bobbin case is a very technical piece of equipment vital to the successful operation of the machine. Even if you get it back together, it requires some very finite adjustments to make it operate properly.
Nov 19, 2016 | Sewing Machines
I have a 1996 buick skylark gran sport , and it kept running hot then it died at light, then started back up, started to run hot again, so i pulled over let it cool and also add water to help cool it down...
You may have done serious damage to the engine. If the water level is fine and you didn't blow your head offs when you penned the radiator cap like it tells toy not to when hot, it's the water circulation pump failing.
Water pump needs to be replaced. Don't keep driving it like that. It's bad bad bad for your engine. Unfortunately a water pump isn't typically easy to replace, seek professional help.
Feb 26, 2015 | Buick Cars & Trucks
Jan 13, 2015 | Washing Machines
How to set up welder or aluminum tig welding
If you want to weld aluminium with a welder, your machine must be an AC/DC welder, then you will use only AC to do the weld, but as well you must have a contineous high frequency and according to what thickness you want to weld a water cooling argon torch wont be a luxury
Aug 25, 2014 | Welding Tools
No hot air in zanussi dryer td 160 t
I'm not an appliance engineer nor am I familiar with this make and model but depending on your technical skills you may be able to identify the problem by means of testing internal parts with a multi-meter.
If you feel that the machine will otherwise be binned you have little to lose.
First you must take into consideration safety of yourself and others who may use the machine.
You'l also need a variety of basic tools and a mutli meter.
!ENSURE THAT THE APPLIANCE IS DISCONNECTED FROM THE ELECTRICITY SUPPLY!
You can remove the outer casing and test for continuity in; heater elements, motors, fuses, switches and any wiring from terminal to terminal.
Look for any obvious signs of wear and tear or any possible causes; burnt out components on circuitry, trapped or worn wiring, broken parts etc.
Ensure that when putting it back together anything you may have disconnected is reconnected!
Disconnecting any earth terminals would fail the machines vital safety function. This is of great importance due to the machine using both water and electricity!
Nov 20, 2011 | Zanussi Dryers
Cleaned filter,found some money. put it all back together but still there is leaks from this area. the machine has not been used for a week and all hoses pipes seem fine.cant figure out where water is...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
Aug 03, 2011 | Washing Machines
Poor cooling
cold air is made by refrigeration in the air conditioner. If the unit is low on the freon charge then you have a poor exchange and poor cooling. I have gotten the units to work better by putting a little water on the outside exchange coil. by bringing the temp down on the outside coil you get a better exchange and better cooling. I used a small copper tube with about 10 real small holes in it to drizzel just a little bit of water on the outside part of the machine. the fan cools off the outside coils off and gets a better exchange bringing down the temp of the air coming out of air conditioner
May 01, 2011 | Heating & Cooling
WATER PUMP REPLACE DIAGRAM
  1. Step 1 Drain the antifreeze from cooling system. Remove belt from water pump. Examine and see if you have to remove anything else to get out the water pump. If so make a diagram of everything you are removing so you can put it back together.
  2. Step 2 Remove the hoses from the water pump. Find all bolts holding the water pump in . Loosen each one a little bit. After all are lose you can then remove them. Remove water pump. Put new gasket on and install new water pump. Hook up hoses to water pump. Look at your diagram and replace everything you had to remove earlier. Put the belt back on.
  3. Step 3 Shut the drain on system and refill cooling system. Make sure you use the antifreeze that is designed for system. Run engine for a couple of minutes. Check for leaks and check coolant level. Add if necessary. If there is no leaks you are ready to go.
Jun 04, 2010 | 2001 Mazda MPV
Regarding the delongi pac 50 is it vital to have water constantly in the machine when it is on? if it is on and there is no water in the container will it burn the machine out?
The water in the machine comes from the cooling coil, and is condensate. This happens with all cooling systems. And no, no water in the cup will not burn the machine up.
Please reply if you are having problems with the unit.
Dec 17, 2009 | DeLonghi Pinguino PAC-77E Air Conditioner
Water Filters & Coolers Logo
165 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
