Question about Grundig Televison & Video
Grundig GU371080B 37inch TV in digital features it says no common interface module present is this anything to do with tv reverting to analogue tv when switched off ?
SOURCE: Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Posted on Apr 19, 2008
  • 280 Answers
SOURCE: unable to view digitial tv pictures but audio and analogue pictures work
If you have cable and a top of set box , it may be the problem. If you hook the cable direct to the set and still no digital ... then the TV could have a defective digital board. The tuner is on this board and the tuner gets both analog and digital signals.
Posted on Jul 11, 2008
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
budmrtn
  • 11361 Answers
SOURCE: Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 17, 2009
jdvillanueva
  • 2098 Answers
SOURCE: wharfedale 37inch tv will not
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Jun 27, 2011
Removed TV from cable,connected a antenna.Changed setting to antenna.All I get is a Blue screen like no signal is coming through.Connections are good. It seems like a setting is missing. Help
Hi, is the tv set to analogue broadcast, should it not be set to digital. I have a Grundig that does the same thing on analogue.If your tv is and/digi this might be the issue.
Jun 16, 2015 | Apex Digital Apex At2002 Color Tvs
Grundig tv loses the digital channels
Did you try disconnecting the TV for a few hours to reset it?
Mar 03, 2008 | Televison & Video
This received analogue in UK until the switch to digital.Is there a small digibox for this available?
Yes. you can buy an analog to digital; or a digital to analog converter according to your need. It must be interfaced between your TV and cable input.
Jun 08, 2015 | Televison & Video
How do you hook up a VCR player to a TV without a cable box?
Common connection is a scart cable. You will NOT be able to record TV on video tape anymore because the transmissions are now all DIGITAL and VCR's are only ANALOGUE. You WILL be able to play existing tapes if your tv has analogue capability.
Jul 14, 2014 | Televison & Video
Hi fixya I don't have card in PCMCIA slot am told it is not important, I am only watching free view channels not subscription channels all the channels are programmed onto the TV. When TV is connected to...
You don't mention the make or model of your TV, so I am having to take a few educated guesses here: I think you need the common interface module on the TV if it's not going through another receiver. The CIM basically is the thing that allows the broadcast signal to be decoded (free or not). The SkyBox has it's own card and is already doing the descrambling first and then just sends the signal on to your TV.
I am not sure what the "free view box" is that you are using, but it sounds like it doesn't have a decoder.
May 28, 2014 | Televison & Video
I have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Mar 30, 2011 | Grundig Televison & Video
I have a set top box GUDSTB2000 but I can't get sound from TV
hi had same problem with my digi-box
simply unplug box from mains & re-connect.
it worked for me.
cheers russell
Sep 30, 2009 | Televison & Video
Does the Bush LT26M1CA have an analogue tuner
Hi, Your Tv does indeed have an analog tuner for UHF and VHF reception. Remember you need to have an external antenna connected to receive anything via the analog input. On your remote in the upper right hand corner is a button labeled tv/dtv that will switch back and forth between your analog and freeview digital. Good Luck, this should Fixya!
Mar 20, 2009 | Televison & Video
Grundig colour tv lost digital channels
there is prob in tv cicuit . memory ic may be curupt . if u r not a tv technician then connect a tv engineer
Mar 03, 2008 | Grundig GF70-600 TV
Televison & Video Logo
49 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
