Question about Dell Computers & Internet
When on the system monitor shaking
Desktop lcd screen slightly viberation
    Problem Solver:
  • 18 Answers
Maybe we need more information. Try locating the computer away from the monitor if they are next to each other. Maybe try placing the LCD monitor on a soft mouse pad to help absorb vibration.
Posted on Feb 11, 2014
Slightly out of focus screen!
that's crt mointor or lcd
how many buttons in ur monitor
Dec 05, 2013 | Dell Inspiron Computers & Internet
Lenovo z570 screen shaking problem
Hook a spare monitor to the video output usually on the back, if okay! the problem is in the LCD display, if symptoms are the same, you may have a virus, update definitions and run a deep or full scan of your system, if nothing shows, try a system restore and bring the computer back to an earlier time before this happened, if still no result! run a full recovery of the operational system to factory settings.
Mar 13, 2012 | Lenovo IdeaPad Z570 Notebook
My Acer 21.5'' wide screen monitor shakes when I
Get a better stand to hold the monitor. There is nothing wrong with the monitor, it's the operator.
Jun 24, 2011 | Acer Computers & Internet
Sometime screen not still pixel viberation
this problem can happen if the vedio cable is loose or bad. take the the back off panel get the vedio cable make sure its pluged in tight if it is and you still have the problem price and consider replacing the cable
Dec 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
How to troubleshoot flickering, jittering, shaking, or wave-like images on a LCD monitor. 1) Connect the display to the computer. 2) Turn on the computer.
Any monitor has something called a screen refresh rate. If you are replacing your old monitor with a newer one, there is sth called a screen refresh rate that you need to configure. Older monitors (size also matter) have a lower screen refresh rate than the newer ones. If that happens to be your case, find the refresh rate of your new LCD on its manual and adjust it like this.
  1. Right click on an icon free area on your desktop.
  2. Click Properties
  3. On the Property dialog click on the Settings Tab
  4. At the bottom of the form click on Advanced
  5. On the coming property dialog click on the monitors tab
  6. Under Monitor Settings you will find the screen refresh rate combo box, here select the rate that suits you screen and click apply.
  7. confirm your actions in the confirmation window.
Note: Be sure to select a screen refresh rate that matches your screen. If you select a rate bigger than the LCD's capacity you will end up with a black screen on your monitor and won't be able to see the desktop unless you boot in safe mode.
Nov 25, 2009 | Sony VAIO VGN-CS220J/W Notebook
Screen shakes BUT menu is clear (Not shaking) and the power cord solution does not work. What other Ideas are there?
Try installing this Monitor on a different PC. If the problem is then resolved, its your video card.
Jul 25, 2009 | Acer AL1716B 17" LCD Monitor
MSI PM8M -V shaking/vibrating screen
Check the cable connection from the monitor to the computer for bent or damaged pins in the connector. Make sure it's connection is secure.
No problems found there?
try resetting your LCD or CRT monitor. Some CRT's can be degaussed, if yours can - try that.
LCD's, choose factor reset otion if available.
Still no luck?
Right click on the desktop and go to properties, then to settings, then to troubleshoot. Slide the hardware acceleration slider all the way to the left. Click OK.
If that doesnt solve your problem then you could have a bad video card or Monitor. If your video card is on your motherboard, try installing a PCI or AGP card ( if your system is AGP capable )
If you still have the shaking, you should start shopping for a monitor.
Hope this helps,
PC REPAIR
PC REPAIR
Oct 12, 2008 | MSI PM8M-V Motherboard
HP 1730 lcd monitor horizontal glitches on screen. the monitor shows clearly but the screen shakes up and down until it enlarges itself of the screen so you can't see the task bar on thebottom the screen...
find the buttons on the monitor itself,  they control all those things.  I had the same problem myself.  It's not within the operating system --- it's the monitor itself.  It's not display control or any of those things
good luck
Jul 12, 2008 | Computers & Internet
Shaking Problem with LCD Screen - HP Pavilion F1703
It sounds like you need to use your "DeGausse" button to reset the magnetics in the screen.
Dec 25, 2007 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
19 people viewed this question
Alun Cox
