Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Replace transfer unit - Konica Minolta bizhub C250 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
Replace the transfer belt or the transfer roller
Posted on Jan 19, 2016
How do i fix error code 452 in Ricoh Afficio MPC2030
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
Jan 29, 2016 | Ricoh Office Equipment & Supplies
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Installing samsung clx6220 image unit
See page 103 of http://downloadcenter.samsung.com/content/UM/201112/20111205134621713/EN/English.pdf. It looks like the clx6220 uses a transfer belt to transfer all the different toner powders to the paper.
see
http://www.genuinetonercartridges.com.au/genuine-samsung-clp-620nd-clp-670nd-clx-6220fx-clx-6250fx-page-image-unit-transfer-belt.html
The transfer belt unit is refered to also as the image unit !
Also each toner cartridge contains the OPC drum and is replaced when you replace a toner cartridge by the look of it.
You need a transfer belt to transfer the image to the paper and this is why they call it an image unit.
I am guessing that the transfer belt needs replacement !
Sep 08, 2014 | Samsung CLX6220FX AllInOne Laser Printer
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
2002 yukon front end wont engage
2002 GMC Yukon
2002 GMC Yukon
2004 TRANSMISSION Transfer Case - NVG 149-NP (One Speed Automatic) - SUV
TRANSFER CASE NO FRONT DRIVE
Transfer Case No Front Drive
Cause
Correction
DEFINITION: The transfer case is not delivering engine torque to the front propeller shaft.
Review the Symptoms - Transfer Case and perform the necessary inspections.
Viscous coupling faulty 1. Inspect the transfer case fluid for being black. If the fluid is
black, it is most likely caused by a viscous coupling failure.
2. Test for a faulty viscous coupling. Refer to Transfer Case
Description and Operation.
3. Disassemble the transfer case. Refer to Transfer Case
Disassemble in Transfer Case - NVG 149-NP3 Unit Repair.
4. Inspect the viscous coupling for a bulged cover. Refer to
Cleaning and Inspection in Transfer Case - NVG 149-NP3 Unit
Repair.
5. Replace the viscous coupling if it is faulty. Refer to Transfer
Case Assemble in Transfer Case - NVG 149-NP3 Unit Repair.
Planetary carrier faulty 1. Disassemble the transfer case. Refer to Transfer Case
2. Inspect for faulty planetary carrier components. Refer to
Repair.
3. Replace any faulty planetary carrier components. Refer to
Transfer Case Assemble in Transfer Case - NVG 149-NP3 Unit
Repair.
Oct 19, 2010 | GMC Yukon Cars & Trucks
Canon CLC900 error code EO71. Transfer problem? Is solution to replace transfer unit or will some cleaning suffice? Tim Matteson A-1 Business Machines mattesontim@ymail.com
A E071 deals with the transfer drum unit engaging unit. Has the transfer sheet been replaced lately? There is also a drive unit on the back side of the copier for lifting the transfer drum. There is a senor that may be dirty or damaged. Also, is the code a constant or will it show up when ever?
Aug 12, 2010 | Canon Office Equipment & Supplies
Distorted Printout
Causes for distortion or blurring
Cause
Solution
Transfer unit is defective
Replace the transfer unit. Calibrate the printer after
replacing the transfer unit.
Secondary-transfer roller is defective
If it does not rotate smoothly or is deformed, replace the
secondary-transfer roller.
DC controller PCB is defective
Replace the DC controller PCB. Calibrate the printer
after replacing the DC controller
Sep 11, 2009 | HP LaserJet 3055 All-In-One Printer
Transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Jun 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replacing the transfer unit
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
To calibrate the printer, do the following:
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
