I was picking some free channels from the channel store and it froze up, so I disconnected the power to start it over again and it has been stuck on launching home screen for hours.
SOURCE: TV gets stuck on channel, won't advance past channel 7.1
Background:
I'm assuming you have Cablevision. This is becoming a known problem with their broadcasting system. They have been upgrading since last thursday and it has been causing the Sharp TVs to freeze up on channel 7.1. There have been reports of channel 21, 21.1, and 24 as well.
Simple way to fix it:
1. Unplug tv
2. Unplug coax from tv
3. Plug tv back in
4. In the Menu go to Setup > CH setup > CH Memory > Cable (digital)
5. Enable channel skip for channel 7.1
6. Push Menu to exit
7. Change to any other channel
8. Reconnect coax to tv.
Followup:
Avoid channel 7.1 and go give Cablevision a call and let them know about it. They won't do anything to fix it until they get a certain number of reported issues about the problem. Enjoy.
SOURCE: Screen shuts off. Power lite blinks. Aquos 42"
The TV is shutting down because there is an internal fault.
the most common cause for sudden shutdown is overheating.
Ensure that the fans are working.
More causes for sudden shutdown are:
PSU failure.
Inverter failure.
Main board failure.
LCD controller.
Complete troubleshooting can be found on service manual.
Parts and service manual can be purchased from the sellers below, you may need to give em a call.
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Do not forget to leave feedback.
Many thanks
SOURCE: will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
SOURCE: LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
SOURCE: my sony bravia tv is not tunning in all the free channels
Buy a digital antena,will work and recieve better siginal.U have roof antena use that.
