Question about Samsung CLP-315W Laser Color Printer
Image of last print shows up on presant print
Images of previous print shows up in Back ground of present print.
  • 3 Answers
This is usually caused by the left over toner not being properly cleaned from the transfer belt.
Open the printer front cover and close it. Wait for the printer to cycle. It usually make a little noise then stops. Then open the cover and close it again. Then print.
If the first page of the print out is clean. but the next page you print has a shadow of the first page, then you have a a problem with the cleaning mechanism.
Unfortunately the cleaner is part of the image transfer belt assembly which runs about $150 to $200. Unfortunately not terribly cost effective as compared to the original cost of many of these printers.
Good Luck.
Posted on Apr 13, 2014
How do I email a photo
Depends on the phone your using.
If it's an iPhone the best way is to open the image you want to send. In the bottom left corner of the screen it shows a box with an up arrow, press this. You will be presented with a new screen showing the image you had previously open at the top with a tick in the box and a selection of options to send below. Press on the image of an envelope. An email will open with the image in and all you need to do now is enter the address. Hope this helps
Feb 11, 2015 | Cell Phones
Printed copies have ghost images on them. I have never had this problem before., It looks like the image printed twice - once fine and then faint horizontal lines, sometimes some of the previously printed...
1) try doing a full clean from within the menu on the printer, or within the computer software
2) You need to perform a half test. Put a sheet of paper on the manual feeder and do a config page from the information menu on the printer. When the back edge of the paper enters the printer, quickly open the toner door to stop the printing. Now remove the toner cartridge and look at the image below. If the defect is present, then the toner cartridge is the problem 99% of the time. There is a slight possibility that during the conditioning stage of the print process the drum of the toner is not being fully discharged so when the next stage takes places part of the previous image gets put on the toner cartridge again. Very rare. If the defect is not present then the fuser has an issue.
May 04, 2011 | HP LaserJet 2420 Printer
Copy prints with image from previous page (lighter) as well. This is an older copier (Gestetner 2302Z)--is the fuser roller the issue/ Can I repair/replace myself?
To check if it is the fuser rollers turn off the copier before the paper reaches the fuser.Remove the 'jammed paper' carefully as the image will rub off and see if the double image is present.If it not then it sounds like the fuser.If it is there then will more than likely be the drum that is not cleaning.I do not suggest that you change this yourself.
Nov 01, 2009 | Office Equipment & Supplies
The date doesn't show up when I print pictures from my Olympus FE-280 camera. How do I get he date to print on my photo's?
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Jul 11, 2009 | Olympus FE-280 Digital Camera
Settings for date and time on the camera
By default Olympus cameras do not print or show the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
However the computer will only show the date information as part of the photo properties.
Jan 07, 2009 | Olympus Camedia C-450 Zoom Digital Camera
Olympus camera FE-330 day month year installed shows up on review but not on printing
Nov 19, 2008 | Olympus Cameras
Help! Can't date stamp the picture and there are no instructions
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order or print reservation that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Nov 18, 2008 | Olympus Camedia D-580 / C-460 Digital...
Date and time are set but don't show on screen or pictures
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order or print reserve that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Oct 15, 2008 | Olympus Camedia Stylus 300 Digital Camera
Phaser 8560 smudging problem
previous image on a copy are from two things
1-the blanking lamps that erase the image from the drum from the previous copy, and making it ready for the next image is bad
2- the fuser roller is bad and retaining the image on it.
Oct 08, 2008 | Xerox Phaser 8560MFP Laser Printer
I 'd like to show the date on my pictures taken with my Olympus Stylus 600. How could I do that?
Sep 21, 2008 | Olympus Cameras
Samsung CLP-315W Laser Color Printer Logo
126 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
