Question about Umarex HK MP7 AEG, Black USA
Mp7 stuck in full auto even on single fire and will not load
New installation and getting a trickle after shutting off, and not much more than that at full on
there can be a few causes for this , but they all point to one device , the valve for the single handle shower , can be glue stuck inside it from out of new pipes , can be foreign object stuck inside it from new pipes , could simply hooked up upside down , shower valve to inlet and inlet to shower head , also all the new single handles have a automatic shunt that adds cold water to hot water to keep you from freezing or scalding ones self , most of these require a little adjustment (see instructions included in paperwork) and if one hooked the hot to cold inlet and cold to hot inlet this auto shunt will really be confused , why ive even seen them bad right out of box before (although a little rough handing might have been involved with that one)
Sep 23, 2015 | Home
New Project Salvo. Second day tried to use it fires like it is on full auto for a second or two. Wont shoot as semi auto . It drains the CO2 quickly and sometimes the trigger gets stuck on full auto. ...
It's vary common for places to not fill Co2 tanks correctly and it sounds like this is your problem. Try having your tank filled in a different store, If this doesn't work you should exchange the gun at the store you bought it or call Tippmann, they have a excellent 2 year warranty.
Sep 09, 2011 | Tippmann US Army Project Salvo Sniper...
This is the first time I have such device, how can I load music files into the MP715?
if this MP7 player came with an installation disc you might have to set it up before proceding
you will need to connect your mp7 player click start all programs accessories open windows explorer navigate to your music folder the music files possibly a music cd right click on the music files select copy navigate back to the destination drive MP7 player right click select paste or hold the mouse cursor the music files drag them to destination folder MP7 player then drop them in
or if you are downloading music from the internet once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save the music into a folder in my documents or another device (MP7)
hope this helps
Apr 18, 2011 | Computers & Internet
Squeeze trigger once and it fires 3x
if there is a 9 volt battery in the handle, there should be 3 to 5 small dip switchesright by the battery, your set on 3 shot burst, unhook the gas, turn all switches off, and test it, there is also a full auto setting, try different combinations untill you get single shot
Sep 15, 2010 | Tippmann 98 Custom Act Paintball Gun
How do u tell how much transmission fluid goes into the 2000 saturn sl2
It depends on which tranny you have. You either have an MP6, an MP7 or a 4T40E.
The MP6 and MP7 were used on the 1.9L engine.
The 4T40E was used on the 2.2L and the 3.0L
If it's being drained and refilled, the MP6/MP7 holds 4.2 quarts.
The 4T40E holds 7 quarts.
If it's been rebuilt and it's COMPLETELY empty (including torque converter) they hold:
MP6/MP7 = 7.4 quarts
4T40E = 12.9 quarts
If you're just trying to check the level and don't know how much to add, the procedure is to remove the drail plug. The fluid should be level with the bottom of the plug. If no fluid drips out, add fluid until it starts to slowly run out of the drain hole, the tightent the drain hole plug before any more runs out. The fluid will now be at the bottom of the drain hole plug. Keep in mind, this must be done when the transmission is up to at least 104 degrees. Things under there are HOT, so be careful.
Jan 18, 2010 | 2000 Saturn Ls 4dr Sedan
My Bostitch N80 fires full auto when I hook it
I would check the safety first to make sure not stuck because this tool is a bump fire. Let me know and then I will find a kit and schematic for you or you can go to Bostitch.com and find the parts online, but I honestly think that you have a safety issue or the trigger valve is malfunctioning.
Jan 09, 2010 | Stanley Bostitch N80s Nailer -rebuild...
The lens kit of my Sony DSLR A200 produces noise
If it's in continuous auto-focus and doing it, then it is just not locking on to one thing and jumping back and forth between two objects that are very close together in distance and it is normal. It should stop in manual, single shot or single point auto-focus. Sony uses Nikon auto-focus technology and my D-300 with a 70-200mmf2.8 will do it if I turn the auto-focus tracking time(lock-on) all the way down with the auto-focus in full auto.
Sep 29, 2009 | Sony Alpha DSLR-A200K Digital Camera
My sub tank fuel gauge is always on empty even if its full tank
fule gage stuck on half full on 1999 landcruiser. any solution?
Sep 05, 2009 | 1997 Toyota Land Cruiser
Not starting when warm
when u turn the ignition on before firing the starter do you hear a humm? if not maybe petrol pump or auto choke playing up, check ur fuses, under the bonnet2
May 29, 2009 | 1991 Peugeot 405
Umarex HK MP7 AEG, Black USA Logo
Top Umarex Sport & Outdoor - Others Experts
Are you an Umarex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
