Question about Sony Handycam DCR-PC1000 Mini DV Digital Camcorder
GRAY BANDS ON PLAYBACK
We intermittently get gray bands when we playback our videos on the PC-1000. The camera has been repaired once for this problem and has <100 hours of use. FYI: we're using Sony tapes.
The problem comes and goes for no apparent reason.
SOURCE: NO PLAYBACK
According to Sony support, you should follow these next steps: 1. Ensure the batteries are fully charged or the AC power adapter is connected. 2. Remove any media (tape, Memory Stick®, DVD, etc.) from the camcorder. 3. Properly reinsert the media. 4. Ensure the media compartment is properly closed. 5. If the problem continues, try inserting different media. In addition according to your post it is very likely that you busted the tape mechanism. In this case only a certified technician can help you. I hope you work it out
Posted on Apr 25, 2006
  • 64 Answers
SOURCE: Gray bands on recorded tape
The drum is dirty purchase a soft cleaning tape that should do it
Posted on Dec 25, 2007
SOURCE: Playback Problems
Ditto. Old tapes seem to be related to the problem. All I have to do is put in a new tape, play it, remove it, put the old one back in and it will play normally again. I can't explain why. I know the camera has an automatic tape detection feature and I wonder if it is at fault. Perhaps the camera has trouble detecting older tapes and the brains get scrambled. A new tape resets the detector. It's just a guess.
Posted on Jan 10, 2008
SOURCE: very grainy playback
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
QTipsX800Pro
  • 48 Answers
SOURCE: Gray Bars across playback
I hate to say this but you sould bring it for repair to a professional instead of trying to repair it yourself and actually damaging your camcorder. If simple maintenance
repairs don't work like incerting cleaning tapes for 10 seconds.
Please bring it to someone who knows what they are doing.
You'll get your camera back working perfectly for a small fee.
Posted on Feb 23, 2008
Gray lines on my camera during playback
The heads may need cleaning/ aligning or possibly need to be demagnetized. try a head cleaner, iff that doesn't work I suggest a certified repair center.
Nov 29, 2010 | Canon XL2 Mini DV Digital Camcorder
After having dropped my ( 10 inch drop) camera, I am getting gray vertical bars on my playback. I know it's not a low-light issue or a dirty head issue, because the playback was perfect just before the...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 03, 2010 | Canon ZR100 Mini DV Digital Camcorder
Playback has vertical gray stripes
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
Aug 12, 2010 | Sony Video Cameras
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
On the Sony DCR-TRV320E video camera I get two wide horizontal bands on playback and the audio is intermitant. What is the cause?
Having used a cleaning tape several times to no effect. I then went to record, to see if the bands appeared in recording mode. They didn't. So I went back to playback mode and the bands had disappeared.
Jan 28, 2010 | Sony Video Cameras
When I play back my video, I get horizontal stripes of alternating recorded video and image on the screen when I started the playback. The bands are about equal width and there are about ten or eleven...
I assume you are talking about playback on the built-in screen? If so, how do videos look once downloaded to your PC? If they are ok, contact Canon for repair or exchange.
Sep 05, 2009 | Canon ZR200 Mini DV Digital Camcorder
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Gray bars on screen during video playback
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Nov 22, 2008 | Sony Handycam DCR-TRV17 Mini DV Digital...
Black bands and skipping in playback
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
Apr 02, 2007 | Panasonic NV-GS11B Mini DV Digital...
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony Handycam DCR-PC1000 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
