Question about Crosley Washer Motor 6 35-5749-
Maytag PAV3200AWW Washer Motor 35-5749
The maytag washer motor 35-5749, shaft turns freely with no power applied. When power is applied in the spin cycle, apparently the start winding is open and the motor shaft locks up until power is disconnected. Is the start winding controlled by the timer or is it integral to the motor?
5 Suggested Answers
  • 47 Answers
SOURCE: Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
Posted on May 14, 2009
sudel
  • 90 Answers
SOURCE: Washer does not drain or spin after rinse cycle is done.
Sounds like one of the contacts in you programmer is worn out or broken. That means a new programmer.
Posted on May 20, 2009
SOURCE: Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Posted on Jan 09, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Crosley Washer
Possible iff the belt is slipping onthepulley in the higher speed. so the first visuals you can get by having a glance below can give us more information than to speculate the extremes.
Look below the washer, and keep it poised for a good view.when the spin starts look for the noise, then stop the machine unplug and check, can be the belt, can be a spindle friction, a motor noise.. Some oiling can solve.
Posted on Sep 21, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Have checked all recomended trouble shooting suggestions- there must be more?ot drain or spin, motor running, all lines have free flow of water, nothing between tubs and pump pulley moves freely. can
although the pump will turn by hand . when you use the motor power and the belt tenson;. it may be binding. ( this has been a common problem. ) ck for play in pump shaft and look for black under washer from belt fraying . my guess is the pump and also replace belt with the pump // hope this helps. **** and thanks for using fix ya ..
May 04, 2012 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag washer m.mtw58701tw0 doesn`t drain or spin and I just replaced the motor with a new one. What could be the problem?
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. Please rate my answer as 4 thumbs up. thanks. Joe
Oct 02, 2010 | Maytag Washing Machines
Hello,my name is David ,I have a Maytag washer maytag lsg7806aae
can you tell if the motor is turning,if so it could be your idler pulley and youve lost belt tension,otherwise it could be your motor start capacitor if motor spins freely with power and belt off
Sep 01, 2009 | Dryers
My maytag air conditioner turns on you hear the motor but no cold air and the fan does not blow
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 25, 2009 | Maytag M6X06F2A Air Conditioner
My maytag washer will not spin
HI, try to physically spin the drum.there should be some slight resistance but not a lot. if the drum spins freely and, with ease, replace the Motor control board. is has failed in this case.
***Now, if the drum dose not spin freely, this will confirm a failed electric motor.
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Jun 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LR code on Maytag MAH5500BWW washer
i think you better see this link, there is a bulletin issued regarding your problem.
here is the link...http://www.servicematters.com/maytag_library/docs/ITDL-0017-B.pdf
i hope that answers your problem.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Crosley Washer Motor 6 35-5749- Logo
Top Crosley Washing Machines Experts
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
